Gardner hot tube gas engine
Home › Forums › I/C Engines › Gardner hot tube gas engine
  • #60733
    RICHARD GREEN 2
      @richardgreen2
      Anyone making one, or even just interested, take a look at my photos.
      The engine is not finished yet, but some interesting machining photos.
        Richard.
      #2290
      RICHARD GREEN 2
        @richardgreen2
        #60769
        Ian S C
          @iansc
          Good photos Richard, and nice work.  What is bore and stroke of  the motor?  Just a wee hint, May be a 6″ rule or similar in one or two photos near the beginning of the album.
        Ian S C
          Edited By Ian S C on 19/12/2010 00:15:45
          #60779
            Thats comming along nicely.
            Bore is 1 3/8 x 2″ stroke, 9 1/2″ Flywheel
            Jason
            #60783
            Ramon Wilson
              @ramonwilson3
              Nice set of pics Richard and some interesting set ups. Far to big for me but I do envy the versatility of your Elliot. Will this be a ‘true’ hot tube ignition system? I look forward to seeing more on it’s build and eventual running.
              Regards – Ramon
              #60785
              Ian S C
                @iansc
                    That sounds a good size. the open crank engine I’m slowly getting together is based on one featuredin volume one of ME (1898), 2″ bore, 3.5″ stroke, just got some cast iron for the piston, must get on with it again.  I’v made the flywheel out of steel, its 14″dia and 30mm across the rim, its made the same way I make the smaller flywheels for my hot air engines.  I take 3 discs, the first is the center one, it gets bored for the hub, and the spokes cut.  The other two become the rims, these are bolted to the central disc with counter bored holes for the cap screws, twelve in this case,  six in the smaller (4″ to 6″),  I suppose its a model,  it was suggested that it might run a small lathe, the original had  hot tube ignition,  I,m going for a spark at this stage, get it going first. Ian S C
                #60795
                RICHARD GREEN 2
                  @richardgreen2
                  Thanks for all your comments, and to answer Ramon’s question , yes  it will be a true hot tube ignition, although I might also put a spark plug thread in the cylinder head plate so that I can try that option as well, and run it on a trembler coil.
                  Although these Gardners were originally hot tube, ( 1890’s ),  they were made up until the 1920’s,  I think the later ones had various types of ignition including magnetos, so a trembler coil was probably used at some time.
                  I’ll put some more photo’s on as work progresses, probably over the next couple of weeks.
        Richard
                  #60797
                  MikeD
                    @miked
                    IIwepfijkn
                    #60798
                    MikeD
                      @miked
                      I made one of these Alyn Foundry engines with hot tube ignition 10 or 12 years ago, and although it will run perfectly well (on butane gas, but not propane), I have never been able to get the hot tube hot enough with the as supplied design burner. Although it is quite a big engine, I did manage to make it on my Myford S7B, and a drill press, but the flywheel is ABSOLUTELY on the limit of the Myford!
                      I’ll be interested to see how yours runs.
                      MikeD
                      #60803
                        A friend of a friend has built the engine with a proper gas ring inside the hot tube, hopefully they will chip in on this thread, I’ve let them know about it.
                        Jason
                        #60983
                        ronnie barker
                          @ronniebarker18785
                          i have built a gardner from scratch and messed with 2 others to try and get them to run, this is a fun engine to build but a different story to get to run!
                          i made alot of changes to mine from the drawings to get it more to the real thing and to get it to run!!!
                          i built mine 4 years ago but last weekend i saw a friend of mine who has just built a gardner and i cant belive what he has done to it!
                          as jason says my mate has made a gas ring to go inside the hottube which is as it should be, the problem hes had is the engine will run fine on this ring untill he puts the cap on the chimney then the ring goes out and the engine stops not enough upward draft.
                          to over come this he bored the the chimney out as big as he could and put a stainless steel liner in and made the cap bigger problem solved.
                          the other thing robert has done is made the gas tap on the engine a dummy and brought a VERY fine needle valve from mapplins to have better control over the gas.
                          if anybody wants further information on this i will ask him.
                          from what ive learnt you have to have the tube red hot and i mean hot!
                          it would be a good idea to set the engine to run on a spark plug first so that when its running you will know the gas supply is correct for the engine and it will only need the tube setting up
                          best wishes jonathan
                          Edited By ronnie barker on 21/12/2010 19:13:16
                          #114310
                          Jonesthenuke
                            @jonesthenuke
                            Hi, I am currently making one of these. Currently looking to finish the crank, in particular the oil way to the con rod bearing. The drawing shows this facing "inwards" towards the centreline of the main bearings, which to me seems counter-intuitive. I am tempted to drill in the other direction so that centrifugal action throws the oil outwards into the bearing. I am wondering what the original engine design was, any idea?
                            Chris
                            #114413
                            Ian S C
                              @iansc
                              Chris, perhaps it's that way to some what restrict oil flow, the oil will still get there. Ian S C
                              #114428
                              RICHARD GREEN 2
                                @richardgreen2
                                Hello Chris, I havn't finished my Gardner yet, but thought the same as you about the crank oil hole, I drilled mine as you suggest with the hole pointing outwards, I don't think there will be any problems with it.
                                Richard.
                                #114453
                                Jonesthenuke
                                  @jonesthenuke
                                  Thanks for the replies. I think i will go with the facing outwards approach. The oil feed is only into the centreline of the crank pin from a "trough" that is shallower than the crank pin diameter, so I see no viable mechanism to ensure oil will flow when the engine is rotating. I will also try the Anson museum and see what they have to say.
                                  Chris
                                  Edited By Jonesthenuke on 14/03/2013 18:59:59
                                  #114490
                                  Ian S C
                                    @iansc
                                    On the 6HR Ruston Hornsby that I have a bit to do with the oil hole on the crank pin are outward, the oil is fed from an open ring on the outside of the crank cheek, that is fed by a drip feed oiler. I'm afraid oil management is a bit haphazard because of infrequent use, it should be running 8hrs a day with a load on, as it is, it wouldn't do 8hrs in a year, and the only load it has is a generator with a couple of 40 watt light bulbs. Ian S C
                                    #114513
                                    Jonesthenuke
                                      @jonesthenuke
                                      Thanks for the replay Ian.
                                      In addition I have queried this with the Anson Museum who have (very helpfully) replied as fdollows:-
                                      The original oil hole, as you suggest, goes outwards. When I quizzed Graham who made the original castings for the model, he thought it might act as an oil retaining feature by doing it the opposite way. I don’t know of anyone having a problem with the lubrication but if I was building one I would probably do it opposite to the drawing.
                                      So the consensus seems to be oil hole facing radially outwards, so that is what I will be doing.
                                      Thanks all!smiley
                                      Chris
                                    Home › Forums › I/C Engines › Topics
