Facemill recommendations
Home Forums Beginners questions Facemill recommendations
  • #150634
    Brian Abbott
      @brianabbott67793
      Hello All.
      New to the world of model engineering so apologies in advance for any silly questions that I ask.
      Looking to buy a new face mill together with an Mt3 arbor, anyone have any favourites suppliers they could maybe recommend ?
      thanks.
      #7124
      Brian Abbott
        @brianabbott67793
        #150640
        Thor 🇳🇴
          @thor
          Hi Brian,
          you don't say what diameter you want, I assume you want one with carbide inserts. I have a 32mm Glanze from Chronos, that has worked well. You can get larger diameters if you want.
          Thor
          Edited By Thor on 25/04/2014 05:15:19
          #150655
          Brian Abbott
            @brianabbott67793
            Thanks for the reply, was looking into maybe a Ø50mm with a seperate Ø22mm arbor, but will look into the range that you have suggested, worried about buying rubbish i guess.
            thanks again
            #150660
            WALLACE
              @wallace
              The Glanze ones are quite tough ! I used mine to machine out stainless steel and it did the job well – they’re certainly not rubbish !
              W.
