Face Knurling…
Face Knurling…
Home Forums General Questions Face Knurling…
Viewing 25 posts - 1 through 25 (of 28 total)
  • #539109
    jon hill 3
      @jonhill3
      I was toying with the idea of making some deep fit acorn style cycle/motorcycle wheel nuts as I cant find a supplier for 3/8 bsc 26tpi x 20mm deep.
      I thought it might be a simple project however with commercial wheel nuts they often have a serrated edge to retain on the fork. I know I could use crown washers or some similar option however how would I go about knurling or serrating the face of the nuts?
      #28100
      jon hill 3
        @jonhill3
        #539112
          Take a bog standard knurling tool and set the height either much lower or higher than usual, flip the end up/down so only one wheel is engaged and feed into the slowly rotating face.
          Alternative is to set up in the mill and cut two sets of Vee Grooves at 90deg to each other into the face.
          #539116
          jon hill 3
            @jonhill3
            Thanks Jason
            What about hard steels such as 316 stainless, would the knurler work as well? I presume the above is aluminium..
            #539162
            old mart
              @oldmart
              If you have a rotary table on a mill, you can produce the knurling, it just takes time. Washers with the knurling in association with nuts would be better, then the knurling will grip, but not be rotating when the nut is tightened.
              Edited By old mart on 11/04/2021 15:47:35
              #539164
              larry phelan 1
                @larryphelan1
                Jason, you do have a simple answer to most things !
                Never needed to do this, but who knows ???
                Thanks for the tip.wink
                #539165
                david sanderson 3
                  @davidsanderson3
                  Jason I'm curious how you machined the hole in that part with the flat
                    I've not tried it on stainless but would think it would need a lot of pressure applied to it.
                    Hole forming here
                    #539188
                    DiogenesII
                      @diogenesii
                      Just musing out loud, but might there be a way of 'cut-knurling' these.. ..driving the shallow-angled corner of a wheel across the face.. ..can't remember whether I've seen it done or not..
                      ..only posting in the hope it might jog someone else's memory..
                      #539190
                        Yes you can do it like single point cutting a bevel gear, just rotating the work in a vertical rotary table with a Vee pointed cutter held in a shaft in the spindle.
                        Also worth noting that cycle "track nuts" are actually in two parts with the knurled "washer" captive on the nut so you don't chew up the dropouts when turning the nut, the knurl is there to stop the axle shifting under side load from the chain not to stop the nut coming undone.
                        #539197
                        Oily Rag
                          @oilyrag
                          Jon,
                          Why are you using stainless steel for a critical item such as an axle nut? I certainly hope you're not using it for the axles themselves!
                          Racing motorcycles are prohibited from using stainless for wheel spindles after the death of Fritz Scheidegger at Mallory Park 50 odd years ago. Stainless has a high 'notch sensitivity' and his front wheel spindle failed under braking for the hairpin corner. Race Scruitineers check wheel spindles with magnets to enforce the ruling, this can, unfortunately, rule out other non magnetic materials such as titanium, although titanium is a far safer material due to its far higher ductility and toughness, apart from its excellent resistance to corrosion.
                          I would never ride a bike with stainless steel used in such a critical item, its OK for non critical fasteners but that is all.
                          Martin
                          #539199
                            From Jon's earlier posts I think it's for a push bike.
                            #539204
                            Oily Rag
                              @oilyrag
                              Jason,
                              Accepted that it may be for a push bike – but to quote Jon "….toying with the idea of making some deep fit acorn style cycle/motorcycle wheel nuts". I've seen far too many wheel spindles on custom motorcycles made from stainless due to what I think is referred to as 'a little knowledge can be a dangerous thing'.
                              Scheidegger's death was a warning that even apparently highly skilled engineers need to be aware of the metallurgical dangers of a 'little knowledge'. The spindle broke at a size transition area due to tool marks even though a radius had been provided, the sudden break then caused a catastrophic failure at the other end of the spindle at another transition point. A front wheel detaching under heavy braking is not a nice experience to witness as I happened to at the time.
                              The other warning I would emphasise is the practice of chrome plating frame tubing, known to cause hydrogen embrittlement of the tubes; fine to use nickel plating but chrome plating is again frowned upon. In fact a lot of motorcycle racing sidecar frames were left bare metal and just varnished – this allowed for a visual inspection of the tubing for cracking to alert the owner of potential failure.
                              Martin
                              #539224
                                Posted by JasonB on 11/04/2021 19:52:43:
                                It might be a mountain bike … in which case may be stressed more than a road motorcycle…
                                jon hill 3
                                  @jonhill3
                                  I did not know that stainless wheel nuts could cause problems or chroming of motorcycle frames.
                                  While we are on the topic of exotic metals for wheel nuts I have noticed that a certain well known auction site has anodised aluminium wheel nuts for cycles. Should I be more worried about these as alleys record for metal fatigue is surely more of a concern than stainless on a pushbike even if it is used occasionally off road?
                                  #539251
                                  CHAS LIPSCOMBE
                                    @chaslipscombe64795
                                    Oily Rag:
                                    Thanks for a most interesting post. What are your views on stainless steel spokes? These seem to be popular on motorcycle restorations these days. My motorcycles are all pre-1930 and not massively powered but I still use non-stainless spokes. I don't know what type of steel they are.
                                    Chas
                                    #539267
                                    colin wilkinson
                                      @colinwilkinson75381
                                      Oily Rag, Titanium has been banned by the ACU for some time. From Standing Regs
                                      14.20CONSTRUCTION
                                      The use of titanium in the construction of the frame, the front forks, the handlebars, the swinging arm spindles and the wheel spindles is forbidden. For wheel spindles, the use of light alloy is also forbidden. The use of titanium alloy nuts and bolts is allowed.
                                      #539271
                                        With spoke threads being rolled rather than cut I would have thought there should be less of a risk
                                        As for Chrome, it was very popular on forks and the rear triangle of all quality bicycles before more exotics came along
                                        When I used to ride my MTB I had aluminium nuts on the titanium skewers, think they were only M5 thread but can't remember what the ali was, probably a 7000series
                                        Plenty of Titanium framed bicycles around too as well as aluminium wheel spindles (On Mountain bikes too Neil)
                                        Edited By JasonB on 12/04/2021 07:49:13
                                        #539273
                                        Hopper
                                          @hopper
                                          Posted by CHAS LIPSCOMBE on 11/04/2021 23:43:52:
                                          Oily Rag:
                                          Chas
                                          Stainless steel spokes seem to work just fine and are readily available from reputable suppliers such as Buchanans in the USA. Plenty of big horsepower Harleys using them. I have used them on Harleys and on a Rocket 3 (over-) restoration without problems. You can polish them to look like chrome or leave them natural or if you bead blast them they look closer to the old cadmium plated spokes than modern zinc plating does.
                                          Make sure to use anti-seize on the threads if using stainless nipples too, or they can gall and lock up if you ever want to tighten them up down the road sometime.
                                          #539276
                                          Ex contributor
                                            @mgnbuk
                                            Stainless steel spokes are original equipment on my RE Interceptor 650 and my wife's Moto Guzzi V7 Special & I rebuilt one of my MZs wheels many years ago with a set of stainless spokes from Central Wheel Components (at one time the supplier of Triumph's spoked wheels). MZ OE spokes were chromed steel.
                                            I recall many years ago there being an on-going spat in the letters pages of the original Motorcycle Sport magazine between two suppliers of stainless aftermarket wheel spindles getting increasingly vitriolic WRT the "correct" grade of SS to use in such an application. Always stuck with OE parts for tcritical parts, but note that at least some wheel and swing arm spindles (BMW & MZ come to mind ) appear to be hard chromed.
                                            Nigel B.
                                            #539279
                                            martin haysom
                                              @martinhaysom48469
                                              lots of stainless fittings used on aircraft just need to use the right grade.
                                              #539316
                                              jon hill 3
                                                @jonhill3
                                                As oily Rag has mentioned about the dangers of stainless in high stress applications such as motorcycle wheel nuts can anyone give me some data…..
                                                I dont doubt what people tell me but I like to see the data and context, also it seems to me to be a sweeping generalisation to lump all stainless steels as dangerous for such uses as motorbike wheel nuts.
                                                #539318
                                                Hopper
                                                  @hopper
                                                  Oily Rag was talking about the dangers of stainless axles, not nuts.
                                                  And the data can be deceptive. Stainless bolts can have same or even higher tensile strength than carbon and alloy steel fasteners. But it is stainless's tendency to work harden and fracture under repeated severe load cycles that causes the problems. So things that get a repeated hammering like axles or caliper mounting bolts can fail. Nuts, not so much. And stainless fasteners used for things like holding an oil tank or seat in place are fine.
                                                  Edited By Hopper on 12/04/2021 12:07:07
                                                  #539338
                                                  jon hill 3
                                                    @jonhill3
                                                    Thanks for clearing that up, one more related question: if you mix stainless with ordinary steel will the ordinary steel corrode more just like a battery?
                                                    #539357
                                                      Posted by jon hill 3 on 12/04/2021 11:40:50:
                                                      I too dislike sweeping generalisations! Hard to avoid because few Model Engineers have a professional background in materials science, or the time and interest needed to tackle the subject in any depth. Thus we bundle vague ideas about entire families of alloys together, and often as not it's good enough to understand the broad differences between 'steel', 'aluminium', and 'brass', even though these all have wildly varying properties, good and bad! We're happy as long as metal machines reasonably well and doesn't break. Ignorance is bliss!
                                                      Fortunately, engineering for strength and reliability isn't often required in Model Engineering. As not much of my work is safety critical it doesn't matter my approach to metals is naive. I like Aluminium alloys because they are cheap, Brass because it it machines well, and mild-steel because it's strong and hard enough for what I need. I use what I have rather than buy in the most appropriate material for the job. My workshop choices are pretty brainless!
                                                      Slapdash methods aren't smart when the engineering has to be safe. Brakes, lifting gear, motorbike axles, wheel fixings, engine mounts, and anything where people get hurt if it fails need proper attention. To keep life simple there is a lot of general guidance around, such as building codes and type approvals, that tell constructors what to avoid, without going into detail. Behind the scenes, appropriately qualified engineers do the design, including selecting the suitable materials. Constructors can then apply their skills without needing to understand a mass of complicated design detail. It's iffy for constructors to modify or re-apply a design on the assumption they understand it! Might be OK, might not. Design decisions based purely on experience could be guesswork rather than understanding.
                                                      So as soon as someone might get hurt if a home-made part fails, it's necessary to look things up. Assume nothing. Read specifications, do the sums, and apply risk analysis. It's a thinking job. Bear in mind that the part might have to pass an amateur test such as magnetism; testing for stainless steel with a magnet is crude, and it might allow a mechanically unsuitable stainless through, whilst denying a well-chosen stainless because it happens to break the rules. Not daft, because the chap with the magnet is following a general guidance with a good chance of detecting a dud material with a simple test. Point is designs have to satisfy all the requirements, not just survive a short test drive.
                                                      If I wanted to make a wheel nut out of stainless, I'd start with the specification of the original and ensure the substitute was at least as strong. Where it gets complicated is the need to account for subtleties like work-hardening, fatigue cracking, and temperature sensitivity. This is why thousands of different steels are available, and several hundred different varieties of stainless, each designed to excel at a particular job. I'd also worry about why the original was drop forged with rolled threads – both methods are stronger than machining from stock.
                                                      WW2 Liberty Ships are an example of getting it wrong. A number, all virtually brand-new, fell apart at sea and in harbour.
                                                      Two reasons were identified. One was cutting cargo hatches with stress-raising sharp corners, the other was building the ships with a mild-steed steel alloy that becomes brittle below freezing point. The steel was fine for most stormy Atlantic crossings, but not for ships routed far North in some of the coldest winters ever recorded…
                                                      Using the correct materials and processes is about reducing risk. Replacing a motorbike wheel nut with a third-rate substitute doesn't guarantee failure: in practice, there's a good chance will last a long time – forever on a display bike. Doesn't mean the repair is acceptable. Foolish to put the same nut on a performance bike ridden aggressively over rough roads for hours on end.
                                                      Edited By SillyOldDuffer on 12/04/2021 14:39:30
