electrical question
electrical question
Home › Forums › General Questions › electrical question
  • #99960
    ronan walsh
      @ronanwalsh98054
      I have a colchester master lathe which i run from a yaskawa vfd , it will run up to a 5 hp motor well and its a great bit of kit, recently i bought a tom senior milling machine and it is three phase 2hp.
      Rather than buy a seperate vfd to run the mill is there any type of directional switch that i could use to switch the output from one machine to the other ? Not while the unit is powered up of course.
      #22242
      ronan walsh
        @ronanwalsh98054
        #99962
        KWIL
          @kwil
          One thing about VFD is that they are set up for a particular motor and the current/phase is set so as to protect the motor. You could switch it over as you suggest, but personally I would not. You can buy a 2hp VFD quite cheaply and so avoid the pitfalls.
          #99963
          ronan walsh
            @ronanwalsh98054
            Thanks kwil , i did forget about the setting up part.
