Drill Chuck Runout
Drill Chuck Runout
Home › Forums › Workshop Tools and Tooling › Drill Chuck Runout
  • #18481
    Enough!
      @enough
      My chuck has suddenly developed a case of the wobblies
      #293401
      Enough!
        @enough
        I have this decent (Rohm) 5/16" keyless drill chuck. A few weeks ago I put it on the mill and found that it had developed highly noticeable runout …. the kind of runout that I couldn't have missed previously. I'm careful with this chuck and certainly don't recall any serious accidents. I just checked the runout as follows:
        The runout on the spindle and on the arbor shank (point A) was negligible. The runout on the chuck at point B (measured with a centre drill installed) was 0.02" TIR.
        The chuck is tight (very) on it's Jacob's Taper arbor and in the absence of any severe handling – which I swear it hasn't had – I don't really know what would cause this to suddenly occur.
        – notwithstanding the tightness of the fit on the Jacobs Taper I'd like to remove/refit it (and perhaps check the runout of the JT vs the shank) does anyone have a recommendation for getting these apart (without being rough on the chuck of course).
        – Any other suggestions as to what might have caused this?
        Edit: just noticed that the leader-line from The 'B' label seems to have gone walkabout. Just imaging a horizontal line from 'B' to the chuck body.
        Edited By Bandersnatch on 15/04/2017 01:03:14
        #293403
        Enough!
          @enough
          Hmm – always the way – having posted that and looked closely at my own picture, it looks to me as if that spline at the top has moved out. I thought at first that was its normal position but having checked some pics at the Rohm site I think it may have shifted. I'll try pressing it in tomorrow.
          #293413
          Spurry
            @spurry
            To break the taper just get yourself some Chuck Removal Wedges, sized for the taper.
            One example from Arc
            Pete
            #293414
            roy entwistle
              @royentwistle24699
              For the B measurement I would have gripped something in the chuck rather than use the chuck body
              Roy
              #293500
              Enough!
                @enough
                Spurry – they look handy. I'll look around on this side of the pond …. or perhaps I could make something.
                Roy – yes, I probably should have done – and would have done if I'd been looking for a precise value – but I was only after a ball-park.
