displacement lubricator on 5″ loco
Home › Forums › Beginners questions › displacement lubricator on 5″ loco
  • #113295
    nigel jones 5
      @nigeljones5
      Im thinking of a simple lubricator for my 5" – Ive used them on stationary engines fine, but would it work on a loco if I take the feed from the valve chest? I cant access the steam in pipe easily.
      #6602
      nigel jones 5
        @nigeljones5
        #113365
        Sub Mandrel
          @submandrel
          Hi Fizzy,
          I think with a displacement lubricator oil delivery depends on steam pressure – OK for a more or less constant speed stationary engine, but perhaps not ideal for a loco that keeps stopping and starting.
          I think that for loco use a sight feed is added to the basic displacement lubricator so you can monitor flow, and I think it may be linked up to the lubricator in some way. I suspect it could end up more complicated than a pump.
          Edited By Stub Mandrel on 28/02/2013 21:01:23
          #113373
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Hi Fizzy ,
            Displacement lubricators can be mounted on valve chest easily and will work perfectly – nothing different to mounting them on valve chest of a Stuart no 10 .
            Don't make them complicated ones though – follow what was done on simpler industrial locomotives which just had a simple oil pot dislacement lubricator with basic means of filling and draining .
            Regards ,
            Michael Williams .
