> Kerosene ignites when vaporised so I doubt if any one uses that on a tool grinder.
I used to, paraffin or paraffin-based mixes are recommended for diamond wheels. No more hazardous than using it to cool aluminium when milling.
A gently application to the diamond wheel with a small brush, but I found that HSS doesn't really cause me any problems without it.
It doesn't get hot enough to generate noticeable vapour because the cuts are so tiny.
