Degreasing internal 3mm thread
Home › Forums › Beginners questions › Degreasing internal 3mm thread
Viewing 15 posts - 1 through 15 (of 15 total)
  • #797782
    Mike Quinn 1
      @mikequinn1
      Hello
      what would be the best way to degrease an internal 3mm thread approx 25mm long.  It will have a 3mm threaded rod JB welded inside eventually.
      just want to make sure its clean before gluing.
      Any help appreciated.
      #797786
      Mike Quinn 1
        @mikequinn1
        This is an aluminium piece.
        #797787
        Peter Cook 6
          @petercook6
          Lots of brake cleaner, and an old (well cleaned) mascara brush liberated from a friendly female (or male who uses mascara!).Although the bigger question is why the thread needs to be 25mm long @m3. That’s 50 threads in engagement. Rule of thumb seems to be 1.5 x bolt diameter i.e 4.5mm or 9 threads seems to be optimum.
          #797791
          Wink Hackman
            @winkhackman25989
            Use a Tepe interdental brush – the green one will be just right – dunked in acetone.
            #797804
            John Haine
              @johnhaine32865
              Or perhaps a cotton bud screwed in
              #797808
              Pete
                @pete41194
                How large is the aluminum part? For anything smaller sized, I’d start with a long soak in something like that acetone. Then run the correct tap through it to loosen anything left and another soak in clean acetone. Repeat a few times if needed, and de-greasing the tap as well before it’s used each time to prevent any re-contamination. Brake cleaners work, but a bit better in my opinion would be a spray can of electrical contact cleaner since it’s designed for the task and evaporates quickly. Either should still work. And unless the threads are a really sloppy fit, one of the Loctite products might also work better than the JB Weld, again either might work. But any excess and still liquid Loctite is a lot easier to wipe off than JB is. And because of the product design, it’s viscosity and how it’s meant to work. Loctite might well be a stronger and more durable method.
                #797811
                Neil Lickfold
                  @neillickfold44316
                  Pipe cleaner with the grease and oil remover(Painters prepsol) then rinse with the loctite cleaner. Loctite 648 works well to glue ali threads and if going to 250c then use 620 high temp. But 620 is very slow curing. JB is very fast curing by comparison. You can thin JBweld by heating it and the parts to 40-50 c before assembly. It will cure in about 3 hrs at 50c
                  #797841
                  bernard towers
                    @bernardtowers37738
                    brake cleaner and 25psi of air job done.
                    #797849
                    Bazyle
                      @bazyle
                      If it is open both ends remove the thread from  lot of it to the as measured clearance for the threaded rod. You don’t need ten times the diameter of the thread all locked.
                      #797855
                      Andrew Crow
                        @andrewcrow91475
                        I have mentioned in a previous thread the use of cigarette lighter fuel, the container has a small nozzle to enable fluid to be squirted down the hole, use the tepe brush as stated above followed by a quick blast of air.
                        Andy
                        #797876
                        Robert Atkinson 2
                          @robertatkinson2
                          If squirting anything down the hole, including air, wear proper eye protection.
                          About 28 years ago I was doing this task on a large aluminium alloy cylinder. I grabbed a pressurised can of “Solvent Cleaner” that had been donated to the project. It seemed to work but several seconds later there was smoke coming out of the M4 tapped hole! The solvent was carbon tetrachloride and started a exothermic reaction with the finely divided and unoxidised (due to tapping oil) alloy particles. It had been donated because the ban on it’s sale and use was looming and a donation saved the supplier paying for disposal….
                          Robert.
                          #797889
                            Robert.
                            In some firms it’s a sacking offence to clean out with compressed air.
                            #797897
                            Andrew Crow
                              @andrewcrow91475
                              Robert.
                              When I said “a quick blow” I meant my own lung power 😅
                              #797916
                              Martin Kyte
                                @martinkyte99762
                                Why threaded? Why not a plain 3mm hole with high strength loctite.?
                                #798491
                                Mike Quinn 1
                                  @mikequinn1
                                  Hi
                                  thanks for the suggestions.  I’ll post some pics of what i’m doing and what it for.  I might be reinventing the wheel to be honest.
                                  cheers
                                  mike
