Cut down DRO
Cut down DRO
Home › Forums › Manual machine tools › Cut down DRO
  • #491724
    Nick Clarke 3
      @nickclarke3
      I am thinking about adding a Z axis DRO to my SX1L micro mill.
      If I bought one of the inexpensive (aka cheap!) remote DROs like this one from WARCO **LINK** could I shorten/cut down the scale as I will only need about 3" of travel on a small machine like this at max?
      #14004
      Nick Clarke 3
        @nickclarke3
        #491727
          Posted by Nick Clarke 3 on 21/08/2020 12:09:19:
          Looks identical to the type I cut down for my mill. No bother at all.
          not done it yet
            @notdoneityet
            I have been content with the twin axis readout for my lathe (**LINK**). Marginally more expensive for a single channel, but cheaper if two scales are needed. It has worked well (within its specification – reads only to 0.01mm or 0.001” .
            Scales can be shortened (its in their description 🙂 ).
            Unless you specifically need a remote readout the scales are cheapeper by a lot.**LINK**
            edited to get rid of the emoticon glitch thing🙂
            Edited By not done it yet on 21/08/2020 12:55:48
            #491737
            Stuart Smith 5
              @stuartsmith5
              I fitted one to my Warco WM16 in place of the standard one. I have made a small circuit to connect it to a cheap android tablet running the TouchDRO app. ( I have 3 axes ) .
              I cut it to length with no problems.
              I initially fitted 2 of these to the x and y axes but found the display as supplied a bit small, so that’s why I am using the TouchDRO app. Plus it has extra features.
              Stuart
              #498691
              andrew lyner
                @andrewlyner71257
                Posted by SillyOldDuffer on 21/08/2020 12:22:24:
                I had a look at them but I worry about where the readout will be. How readable is it if it's mounted low – or, alternatively, when mounted higher, how vulnerable would it be to things going on on top of the milling table?
                The price is pretty attractive, of course.
                I am just basking in a sea of smug today. My second hand Sealy milling machine had a very iffy speed control but I have just replaced the switch / pot and it works a dream. I feel more inclined to do some more things on it, rather than with it!!
