Countersink cutter
Countersink cutter
Home › Forums › General Questions › Countersink cutter
  • #22805
    Paul Lousick
      @paullousick59116
      #128563
      Paul Lousick
        @paullousick59116
        I have to machine large countersink holes in 8, 12 and 20mm steel plate, up to 38mm x 90 degrees with a Sieg X3 mill.
        My options are to buy or make a countersink cutter. Which way to go ?
        Have seen 40mm HSS single flute cutters on e-bay. Are 1 flute cutters any good >
        Also 2,3,4, or 6 flute cutters. Which are better ? (Would like a replaceable carbide insert cutter but expensive). Does anyone have any expeience or suggestions ?
        Paul.
        Edited By Paul Lousick on 04/09/2013 14:13:07
        Edited By Paul Lousick on 04/09/2013 14:14:01
        #128582
          @mike89748
          I can only speak from personal experience, which suggests that the fewer the flutes, the less likely the countersink is to chatter. My choice would be a single-flute cutter in HSS. What do more experienced engineers think?
          #128583
            Generally speaking … odd numbers of flutes [cutting edges] seem less prone to chatter than even numbers.
            For your job, I tend to agree with Mike …
            Sub Mandrel
              @submandrel
              I'd vote for a single flute, I'd even consider making one from silver steel, although it will have to be treated gently.
              Don't bother with the ones that have a hole through a cone, they are really only deburring tools IME.
              The hole size is important too – a 36mm countersink on a 30mm hole isn't a tough task, but one on a 12mm hole is very different!
              mark costello 1
                @markcostello1
                A small boring head or fly cutter with a shaped tool would do the job the cheapest if You have the tools, just not the fastest.
                #128638
                Paul Lousick
                  @paullousick59116
                  Thanks for the feedback.
                  Saw a 40mm HSS single flute cutter on flee-bay for $45 will give it a try. Otherwise may make one with carbide inserts.
                  Regards, Paul
                  #128647
                  Trevor Wright
                    @trevorwright62541
                    A countersink that big is a recipe for mega-chatter on a small mill like the Seig.
                    You need to run the tool as slow as 20rpm to get a clean (not 50p piece) profile with a single tooth cutter.
                    When doing large countersinks in the past – on big machines I might add – I would turn the spindle by hand for the last cuts as the spindles could not go slow enough.
                    Have fun…..by hand I mean with a big spanner or tommy bar
                    Trevor
                    Edited By Trevor Wright on 05/09/2013 13:02:10
                    #128648
                    Trevor Wright
                      @trevorwright62541
                      I have also been known to profile the pocket on the CNC because it was less hassle…….
                      Trevor
                      #128655
                      Sub Mandrel
                        @submandrel
                        My home made cutter would be a conically ended d-bit, so very unlikley to rpocuce an out of round hole, but yes run slowly.
                        Paul Lousick
                          @paullousick59116
                          Thanks for the advice. I can only have a go at producing a decent countersink hole. If not successful will have to find a larger machine.
                          Regards, Paul.
