Copper boiler
Copper boiler
Home › Forums › General Questions › Copper boiler
  • #210008
    Mark Salzedo
      @marksalzedo65030
      Hello,
      I have a coal-fired copper boiler which has been painted black, not particularly well I would hasten to add.
      Will it be in order to remove the paint with 'Nitro Mors'. Will this product adversely affect the copper and/or bushes?
      Many thanks,
      Mark
      #24191
      Mark Salzedo
        @marksalzedo65030
        Copper boiler
        #210011
        Brian Wood
          @brianwood45127
          Hello Mark,
          I can't see any reason why Nitro Mors would attack copper of bronze/brass based bushes. It will remove the paint as that is what is designed to do. so I say use it
          Regardfs
          #210012
          Mark Salzedo
            @marksalzedo65030
            Hello Brian,
            Thanks for that. I just wanted to make sure before I take the plunge.
            Mark
            #210014
            Mark Salzedo
              @marksalzedo65030
              Brian,
              It is a lovely old boiler built by Alec Farmer in 1966. It is 6" diameter and stands about 13" tall with about 40 tubes. These boilers were built to last.
              Mark
              #210188
              HomeUse
                @homeuse
                If you have not used the stripper yet – make sure you soak the stripped boiler in warm soapy water after using the “mors” and then washing well in clean water
