Conversion spreadsheet
Home › Forums › Suggested Online Resources › Conversion spreadsheet
  • #21513
    John McNamara
      @johnmcnamara74883
      Excel sheet covering most Of the SI units.
      #141271
      John McNamara
        @johnmcnamara74883
        Hi All
        Stumbled on this sheet while browsing.
        My computer is quite happy with it and the virus checker said OK.
        This link only takes you to the home page. **LINK**
        You can enter your own values.
        I like the way you can see and check the formulas for yourself, they are protected (Unless you unprotect the sheet)
        john
        Edited By John McNamara on 21/01/2014 14:48:57
        #141279
          Looks useful, John
          Thanks for the link
          JohnF
            @johnf59703
            Still useful but take care it seems to me that much is based on the USA gallon and NOT the imperial gallon this also impacts on the fluid ounce etc etc,
            E.G 1 UK imperial gallon is 10 pounds weight
            1 US gallon is 8.34 pounds weight
            #141285
            Thor 🇳🇴
              @thor
              Thanks for the link John.
              Thor
              #193446
              Gareth Johnston
                @garethjohnston62587
                That is great , thanks very much.
                #193465
                Gary Wooding
                  @garywooding25363
                  I've been using an offline program called Convert for some years. It has lots of different units, including Imperial and US volumes. Just download and install it – its free. Get it from **LINK**
                  By the way, SCAYT tells be that install is spelt instal.
                  Is there a way to change the text colour?
                  #193470
                  Martin Whittle
                    @martinwhittle67411
                    Posted by JohnF on 21/01/2014 18:02:55:
                    Be aware also that the spreadsheet uses the USA 'short ton' of 2000 pounds, not the Imperial ton of 2240 pounds (known as the 'long ton' in USA)
