Colchester Chipmaster Part
Home Forums Manual machine tools Colchester Chipmaster Part
  • #432822
    Paul Valente
      @paulvalente12713
      Good afternoon all,
      Does anyone have a drawing of or could someone do me a dimensioned sketch of Stud 1228 on the Chipmaster. It’s the one that holds the splash guard to the headstock.
      Long shot, but does someone have one for sale??
      Even longer shot, is there a Colchester/Chipmaster expert in the Herts/Beds area who likes beer and giving advice?
      Thanks
      Paul
      #13667
      Paul Valente
        @paulvalente12713
        Sizes
        #432843
        DC31k
          @dc31k
          Two thirds of it is the same as one of the adjacent 1/4"-20 UNC x 7/8" long socket countersink screws that hold the cover on (including the countersink angle).
          So remove one of those to have 67% of your drawing.
          The rest of it is a 9/16" A/F hexagon, 7/16" long with a 3/8" diameter groove in it, 0.150" wide.
          The remaining 33% of your drawing can therefore be determined by measuring the width and thickness of the semi-circular cut out in the splashback.
          #432848
          thaiguzzi
            @thaiguzzi
            Damn!
            Answers like the above is what makes forums a great place.
            Can't ask for better. Kudos.
            #432862
            Paul Valente
              @paulvalente12713
              Agreed, that is an absolutely fantastic reply.
              I’ve actually got the piece down to the base of the taper. All I really need is an exact length for the threaded portion. So it’s 7/8 minus the countersunk angle?
              Thanks
              P
              #432889
              DC31k
                @dc31k
                Posted by Paul Valente on 11/10/2019 16:35:46:
                Which piece do you have? The hexagon part that lives in fresh air or the 1/4" UNC part threaded into the headstock? If the part threaded into the headstock through the aluminium cover is not there (i.e. the female threads in the headstock are clear), it might be a good idea to look inside the headstock to make sure it has not worked its way in there.
                This is a situation where you will be really happy to see the broken off end of the fastener in the casting.
                A countersunk fastener's length is always given from top of head to end of screw so the length of the threaded part itself is not usually given. Your assumption is correct, so what you have to do is determine the countersink angle. I did not tell you this as I cannot remember if UNC is 90 degrees or 82 degrees. Simply remove one of the other screws nearby and copy it.
                #432920
                Paul Valente
                  @paulvalente12713
                  Good Morning,
                  I have the entire component apart from the threaded portion, so I have the hex head, the slotted section that the splash guard slides into and the “male” part of the countersink. The thread snapped off quite cleanly at the base of the taper. The thread was indeed stuck in the headstock. I promptly extracted it and was feeling very pleased with myself for getting it out so cleanly. Of course this is where it all went wrong as I promptly lost the threaded portion whilst cleaning up. So now I’ve got the other piece and can easily take measurements, but need to know an exact length for the threaded portion of the component.
                  Thanks
                  Paul
                  Edited By Paul Valente on 12/10/2019 10:09:13
