capstan sockets – other names for these ?
Home › Forums › Beginners questions › capstan sockets – other names for these ?
  • #334824
    BW
      @bw
      Am looking for mt3 socket inside a straight tube. Googling revealed that capstan sockets are a good search term. The ones I have found seem to be very expensive compared to mt3/mt4 adaptors which are a fairly similar item.
      Postage to Australia is also a consideration, I expected to be able to find something on ebay for approx 10 – 20 dollars with free postage. I can find sets of 4 in usa for 25 dollars but postage is a killer.
      Any other search terms I could use ?
      BW
        @bw
        #334827
        Mark Kilgore
          @markkilgore24274
          ArcEuroTrade calls them "Morse Taper Straight Sockets", but catalog them only in 1MT and 2MT. Still, that might broaden your search.
          #334833
          David George 1
            @davidgeorge1
            try turret lathe socket.
            David
            #334846
            Robbo
              @robbo
              Posted by David George 1 on 01/01/2018 21:57:27:
              David
              also capstan lathe socket
              #334860
              Hopper
                @hopper
                Chronos has them for 8 quid plus shipping, called MT3 socket. Link here **LINK**
                I've been through the same thing before, inexplicably they are more expensive than the equivalent tapered adaptor. Maybe not used as much so lower volume = higher price?
                Course, if you have a capstan lathe, you could crank a few dozen out yourself one afternoon.
                Edited By Hopper on 02/01/2018 08:11:37
                #334883
                Ian S C
                  @iansc
                  If you have an ordinary lathe you might spend a day making one or two. If you get it right, don't stop at one, a couple of spares is good. If you are lucky, as I was you will come across a MT-3 reamer to finish the taper, saves having to be supper accurate with boring, I just drill i stepped sizes down the hole, then skim the hole using a boring bar to ensure the hole is straight.
                  Ian S C
                  #334889
                  BW
                    @bw
                    Thanks for all the help.
                    Bill
