Can gears be bought cheaply or as continuous bar?
Home › Forums › General Questions › Can gears be bought cheaply or as continuous bar?
  • #202289
    Russ B
      @russb
      Does anyone know if gears can be bought cheaply or perhaps as a continuous bar – a bit like you can with T5 toothed pulleys as per below?
      I have a project where I need 4 gears (3 the same and roughly 25-45mm pcd, one perhaps 2.5 to 5 times larger), I will use my lathe change wheels if I have too but I hoped a better cheaper solution might exist.
      Thanks in advance to anyone who could offer assistance, I know I don't offer much (any!?) useful advice on the forum and its because I'm not that useful or experienced. To give a little back I would happily share my project plans with the forum once I've drawn them up as I think some of you might like it.
      laugh
      #24068
      Russ B
        @russb
        #202291
        michael howarth 1
          @michaelhowarth1
          HPC Gears list toothed bar stock.
          Mick
          #202300
          John Stevenson 1
            @johnstevenson1
            but you can't afford it.
            #202320
            Bazyle
              @bazyle
              You are not going to find regular gears much cheaper than change wheels on ebay and they can sometimes be rather optimistically priced. Otherwise random gears from a random bit of scrapped machinery would be the only low cost source. That might be viable if you found a suitable one in a machine that was both common and commonly scrapped – eg a motorbike gearbox.
              #202323
              Robert Dodds
                @robertdodds43397
                Russ,
                You don't give much info regarding the use or loading on your gears but HPC do sell moulded plastic gears for £3 to £5 each and 75mm diameter will come for £12 so if your tooth loading is appropriate you could do worse than look at some ready made plastic gears.
                Bob D
                #202325
                Keith Long
                  @keithlong89920
                  Russ – when Chester Tools have been at the shows they've had a box of gears for you to sort through at cheap prices. Might be worth giving them a ring and see if they've got anything suitable. Otherwise Technobots (satisfied customer) do a range of steel 1.5 and 2 mod gears at reasonable prices – cheaper than most of the change wheels on EBay.
                  #202330
                    Pinion stock or pinion wire is what the lengths are called but if you only want 3 gears it would be more cost effective to just buy 3 gears unless you want very wide ones. Or just machine up a length and part them off.
