Can anyone identify this?
Home › Forums › Beginners questions › Can anyone identify this?
  • #109049
    Luke
      @luke
      Hi all, I was wondering if anyone could identify this item. I thought maybe something for center punching or marking. Two people have them but have no idea what they are. Cheers.
      Edited By David Clark 1 on 18/01/2013 11:40:23
      #6526
      Luke
        @luke
        #109255
        Luke
          @luke
          Nobody seems to know then? The mystery continues.
          #109258
          Brian Wood
            @brianwood45127
            Is anything rotary or sprung built into it?The right hand end seems to be offset from the main body from the flat on the side near the shiny machined diameter. It might be an internal gauge for sizing bores within a limited range.
            What are they made in, stainless steel looks possible and are the through holes threaded or plain?
            #109268
            nigel jones 5
              @nigeljones5
              its a commercial harpoon….for goldfish
              #109288
              Charlie,
                @charlie18171
                Hi Luke
                Its forgetting stones out of horses hooves, To many stones spoil the quality of the burgers,
                #109290
                frank brown
                  @frankbrown22225
                  If that square bit is loose to slide about a little and is magnetis, then its the plunger of a magnetic water valve. The pointy bit goes in a tapered hole to stop the water, when the coil is energised (sits externally around the square bit), the square bit rises and lifts the pointy bit of its seating, allowing the fluid to flow.
                  Frank
                  #109303
                  Sub Mandrel
                    @submandrel
                    It's a tape measure, partially obscured by some lump of metal.
                    nigel jones 5
                      @nigeljones5
                      Neil is right, and if you look carefully you can just make out 5m, which stands for 5 metres (its a metric measureing device)
                      #109380
                      Luke
                        @luke
                        The holes in the body are not threaded. The square part on the end can rotate freely. The pintle like part has a shaft that slides up the main body. No springs to be seen. I guess It does resemble a needle valve of some sort.
                        #109909
                        Takeaway
                          @takeaway
                          3m originally manufactured these but a rival company financed by the Church of England – 5m – remarketed them as "The Vickers Hardness Tester"!
                          #109911
                          Bob Perkins
                            @bobperkins67044
                            Tape measure with an un identified thing on top?
                            #109951
                            Ian S C
                              @iansc
                              Its not a Vickers Hardness tester, thats a 136* pyramid, Rockwell is a cone. I'm sure I'v seen something similar, but I'm getting too many splinters head scratching. Ian S C
                              #109963
                              Bazyle
                                @bazyle
                                Bicycle pedal?
                                #109972
                                Ed Duffner
                                  @edduffner79357
                                  I originally thought a tool for wire fencing, but if that middle shiny part is threaded maybe it's some kind of jack to push things apart and using a pin in the small holes to increase the length of the tool in steps.
                                  I wonder if it's an expandable center for wood turning?
                                  Edited By Ed Duffner on 25/01/2013 12:14:43
                                  #109976
                                  Sandy Morton
                                    @sandymorton10620
                                    The yellow bit is a 5m tape measure – google is your friend. 30-497 is the clue.
