Can anyone help me?!
Home › Forums › Help and Assistance! (Offered or Wanted) › Can anyone help me?!
Viewing 25 posts - 1 through 25 (of 26 total)
  • #456751
    claire dickson
      @clairedickson97927
      I have an old saw and the part where the blade sits on has a screw stuck in it so I need an engineer to get it out for me. Can anyone help please?
      #33545
      claire dickson
        @clairedickson97927
        Tapping and re-threading stuck screw!
        #456802
        David George 1
          @davidgeorge1
          Hi Claire it would help if you can give a little more information ie what type of saw and which end of the saw is damaged a locality of where you are would help.
          David
          #457220
          Chris Evans 6
            @chrisevans6
            Just bumping this thread up. Claire if you are in the Midlands near Lichfield I may be able to help.
            #457242
            DMB
              @dmb
              Claire,
              What sort of saw? Engineers hacksaw, presumably but could be a jewellers, coping or other type? Can you describe it? This applies to all queries; give as much info as possible and/or photo, to boost possible number of responses. I mean this to be helpful, not critical.
              Edited By DMB on 14/03/2020 21:39:47
              Edited By DMB on 14/03/2020 21:41:04
              #458327
              claire dickson
                @clairedickson97927
                It’s a printers saw. Am in Leeds, but my dad lives in London (it’s my dads saw).
                #458328
                Former Member
                  @formermember19781
                  #458329
                  Former Member
                    @formermember19781
                    #458344
                    Speedy Builder5
                      @speedybuilder5
                      Wait for Claire to verify, but pictures on the net look similar to a table saw, 5 or 7" diameter sitting in a big heavy cast iron base. It looks like rotation is normal (Anticlockwise looking on the nut). so should be a normal RH thread.
                      #458357
                      Former Member
                        @formermember19781
                        #458366
                        Samsaranda
                          @samsaranda
                          I think Claire has the saw in her possession by the way she has worded the request so presumably in Leeds !
                          Dave W
                          #458368
                          Bob n About
                            @bobnabout
                            If the screw isn’t totally mangled get some heat on the part, 100℃ or so and add a dab of diesel. Let it soak in for a while 30 mins, and try removing screw with screwdriver, Allen key, mole grips, whatever. Maybe add some more heat and repeat a couple of times. If it’s surrounded by plastic, you’re out of luck.
                            #458392
                            ega
                              @ega
                              If the screw has become overtight through the rotation of the spindle then "shock loading" might be the answer ie hit the allen key, etc.
                              What does a printer's saw cut?
                              #458396
                              not done it yet
                                @notdoneityet
                                Possibly lead strips?
                                #458399
                                not done it yet
                                  @notdoneityet
                                  When someone knows for sure whether it is a clockwise or anticlockwise screw, an impulse driver might do the trick. Otherwise drill with the appropriate left or right handed drill(s).
                                  #458427
                                    Posted by not done it yet on 20/03/2020 14:10:09:
                                    A wealth of information, here:
                                    https://circuitousroot.com/artifice/letters/press/comproom/saw/index.html
                                    ega
                                      @ega
                                      Michael G:
                                      Thank for the link. I did actually glance at the linked page before posing my question; knowing next to nothing about printing, however, I came away without the answer.
                                      As a schoolboy I recall a visit to the Clarendon Press in Oxford and being impressed by the enormous volume of noise from the (?) linotype machines.
                                      #458435
                                        Sorry ega, I hadn’t noticed that the question was yours … I was responding to ndiy’s post.
                                        The answer is ‘type metal’ [such as that used for Linotype], not Lead.
                                        This page [next stop on the circuitous route] links several instruction books and patents: **LINK**
                                        https://circuitousroot.com/artifice/letters/press/comproom/saw/cg/index.html
                                        Edited By Michael Gilligan on 20/03/2020 17:53:15
                                        #458500
                                        Steviegtr
                                          @steviegtr
                                          Mnnnnnnnn.
                                          #458529
                                            Posted by Steviegtr on 21/03/2020 00:01:51:
                                            Mnnnnnnnn.
                                            That’s rather cryptic, Steve
                                            … Could you please elaborate ?
                                            ega
                                              @ega
                                              I hope to hear that someone can help the OP but in the meantime was interested to read some of the material linked by MichaelG.
                                              It seems that some of these old printer's saws had a sliding table immediately to the left of the blade which is the same configuration adopted by modern woodworking saws.
                                              #458540
                                              Cornish Jack
                                                @cornishjack
                                                Presumably the cryptic Mnnnnn is in place of an "I am bored emoji" ?
                                                Possibly the answer to threads to which you have no useful input is … don't make an input!
                                                rgds
                                                Bill
                                                #458542
                                                Former Member
                                                  @formermember19781
                                                  #458645
                                                  Steviegtr
                                                    @steviegtr
                                                    Posted by Bill Chugg on 21/03/2020 09:48:33:
                                                    Posted by Michael Gilligan on 21/03/2020 09:12:17:
                                                    Mnnnnnnnn.
                                                    Please do elaborate as totally beyond me.
                                                    So the thoughts are the saw is in Leeds , so perhaps Dad in London is not relevant and OP is not replying ?
                                                    Bill
                                                    Just very little input from the OP. Lots of members trying to help,,,no reply, Hence the Mnnn.
                                                    Steve.
                                                    #458648
                                                    Former Member
                                                      @formermember19781
