Cam maching by milling
Home Forums General Questions Cam maching by milling
  • #204045
    KEITH BEAUMONT
      @keithbeaumont45476
      I am well advanced making the Chenery Vee twin 4 stroke, from the Hemingway Kit.. I have always intended to use the machining offsets available from the Model Engine News site run by the late Ron Chernich and still available, for machining the cams.However,when I add the required information and press Go, a page comes up saying"A Plugin is needed to display content"
      I am using Firefox 40.0.3 and have Javascript configured.. Rons notes say you need a language"Applet" to make it work. At this point I am stumped!
      Does anyone know the answer to this ,or have knowledge of alternative tables for milling cams?
      #24110
      KEITH BEAUMONT
        @keithbeaumont45476
        #204047
          Hopefully Rod(erkick) will be along, he has a spreadsheet that will do the same job if not drop him a PM
          #204062
          Roderick Jenkins
            @roderickjenkins93242
            Keith
            You should be able to pick up my spreadsheet here:
            I'm away from my PC for a couple of days so I'm struggling with Android on my tablet. PM me if you have any issues. Just change the figures in the blue cells to your figures.
            HTH
            Rod
