Cam gear on Bobcat
Cam gear on Bobcat
Home › Forums › General Questions › Cam gear on Bobcat
  • #98192
    Bengt O
      @bengto
      In the first issue of the BobCat construction series, it's three gears in the Bill Of Material 12, 24,20, how does this work
      KInd Regards ,
      Bengt
      #22212
      Bengt O
        @bengto
        #98198
        David Clark 13
          @davidclark13
          Hi There
          Without checking,
          I would think 12 on crankshaft, 24 on camshaft and 20 as an iddler.
          Four strokes need two to one gearing so that is the 12 and 24.
          Idler can be any convenient number of teeth so 20 it is.
          #98200
            Whats the question?
            Gear details are given on page 302 and as david says 12 on the crank, 24 on the valve and a 20 idler to give the spacing required.
            J
            #98204
            Bengt O
              @bengto
              Sorry, I forgot my brain somewere. I got it now.
              Kind regards Bengt
              #98209
              Sub Mandrel
                @submandrel
                ETW once wrote of how he had striuggled to try and get someones version of one of huis designs to work for ages, without success. In the end he tried to reset the valve gear and in doing so he discovered it had (something like) a 20 and a 39 tooth gear. the maker said "it was all I had, and I thought it would be near enough".
                Mike Wainwright
                  @mikewainwright87512
                  David
                  Any news on the materials list for this engine. It was mentioned in another post but have not seen a reply yet
                  Thanks
                  MIke
                  #98237
                  Ian S C
                    @iansc
                    I would have thought that an uneven number for the idler would have been better for wear, ie., 19 or 21, but it proberbly of little concequence on a motor that is going to have fairly low running hours, (not thousands), just seem to remember some where in the past reading something about this. Stick to the drawings, my ramble over. Ian S C
                    #98239
                    David Clark 13
                      @davidclark13
                      Hi Mike
                      No materials list available.
                      However, Crankcase etc HE30
                      Conrods HE15
                      Piston HE30
                      Steel parts EN1A
                      Crankshaft EN1A or EN8
                      Flywheel mild steel or brass.
                      Cams mild steel case hardened.
                      regards David
                      Edited By David Clark 1 on 12/09/2012 10:36:44
