I'm going through my ticks John. It very much looks like if I want to increase the size range of my work holding collets it will be spring collets and not ER. For tool holding yes ER.
Some of the decision comes from doing a fair amount of collet work but not at home. I don't purchase the wrong thing very often. I have a Bernerd multi size that will match ER40 but has the same problem so it's never been fitted. I bought it because some one who was giving up came along and offered it to me for the same price as Rotagrip offered him. I have also sorted the mounting info for it.
I don't really have any need for bigger work holding collets at the moment but I do need to sort out tool holding. As I have them I'm going to try ER25 with a rather large tool on the end.
Thanks for the thought on holding screw threads for studs John and maybe other thing. Makes me wonder if I can obtain some 3C emergency collets. Rare I suspect so probably stupidly expensive. I'd guess I could do the same with 3 morse blank ends but splitting them would be more work,
I'd beg to differ on 5C and similar types in the UK. Often they are collets designed specifically for the lathe they are on rather than a standard type like 5C but cost has tended to rule them out in the past. It's not so bad now but as I suspected I can buy a 5C collet chuck from the USA that has a sort of spec with it but not in the UK again – other than one seller and the spec was pretty bad. I'm getting pretty cheesed off about that. It's as bad as Ketan's motor power one. CTC is an alternative on ER.
As to the rest I thought it was worth mentioning as the reasons for the difference are real and not some ones imagination. What people choose to do on that score is up to them.
