best tools for aluminium
Home › Forums › Workshop Tools and Tooling › best tools for aluminium
  • #18065
    matthew shay
      @matthewshay62229
      #235138
      matthew shay
        @matthewshay62229
        hi new to using mini lathe I am only going to use aluminium wood and plastic what would be best hss or indexable cardide and if I got hss would I have to buy a bench grinder or would it be easer to use indexadle I am not going to be lathing all the time only when I make things for my model boats any help would be grafull
        #235140
        Vic
          @vic
          You can use either. The polished carbide inserts leave a nice finish but so does HSS if you can keep the tools sharp. So yes, if you want to use HSS you'll need a grinder.
          These folks are good if you go the insert route but there are others.
          Roger Provins 2
            @rogerprovins2
            I prefer well sharpened HSS tooling for aluminium –
            particularly for a finishing cut.
            #235162
            frank brown
              @frankbrown22225
              Same here, once you have invested in a grinder you can use any broken drill as a lathe tool (and you can sharpen blunt ones). Carbide tips need to be selected for a single purpose, so by the time you have bought a selection of 6 different inserts you will be a good way towards buying a grinder.
              Frank
              #235258
              Ian S C
                @iansc
                Grinders aren't just for lathe tools, you'll find plenty of use for it, engineering and woodworking tools, garden tools.
                Ian S C
                #235259
                MW
                  @mw27036
                  Posted by Ian S C on 19/04/2016 13:06:09:
                  Ian S C
                  This is correct!
                  Some of the tools i've ground with a bench grinder i would have never guessed i was going to use it for when i bought it. Definitely worth the money.
                  Michael W
                  #235269
                  KWIL
                    @kwil
                    Interesting isn' it? . I have two 6" double ended grinders, white, green and grey wheels, but rarely use them as I am almost entirely insert tooled. I only grind special purpose HSS tools as and when required.
                    #235271
                    Brian H
                      @brianh50089
                      The grade of aluminium will make a difference too. Ordinary soft aluminium can be difficult to get a nice finish on but the heat treatable ones such as 2014(I think!) are much nicer to work with.
                      #235302
                      Douglas Johnston
                        @douglasjohnston98463
                        High positive rake polished carbide inserts are superb for aluminium and give a beautiful finish. The downside is that they are easily damaged if you are not careful and they tend to be quite expensive. I have been using this type of insert for a few years and rarely use anything else for aluminium.
                        Doug
                        #235309
                        Vic
                          @vic
                          Posted by Douglas Johnston on 19/04/2016 18:00:42:
                          Doug
                          Agreed, these are all the OP needs at the moment as he said he only wants to cut alloy, plastic and wood.
                          #235345
                          Rainbows
                            @rainbows
                            Would you say ground carbide tips give a better finish than HSS? Arceuro sells them for £8 each.
                            #235347
                            Emgee
                              @emgee
                              Hi Rainbows
                              Try this store for a vast range of insert types.
                              Emgee
                              #235349
                              Ajohnw
                                @ajohnw51620
                                These are very good for aluminium and other materials as well
                                They can be fitted to the cheap 10mm / 3/8" sets with the same shaped tips on ebay but if you do buy one of these make sure it comes with torx screws not hex socket ones.
                                The min quantity on the link is 10 but they also offer them in smaller numbers on the hobby tips page.
                                They also work pretty well on mild steel
