Artificial “ivory”
Artificial “ivory”
Home › Forums › The Tea Room › Artificial “ivory”
Viewing 21 posts - 1 through 21 (of 21 total)
  • #628815
    KWIL
      @kwil
      Does anyone know of a current source of suitable material to rehandle some butter knives?
      #37104
      KWIL
        @kwil
        Handles for butter knives
        #628823
        Andrew Moyes 1
          @andrewmoyes1
          Try searching online for 'alternative ivory'.
          #628824
          Chris Pearson 1
            @chrispearson1
            They were usually made of bone. If you can find a proper butcher, you may be able to get an ox's femur.
            #628829
            John Haine
              @johnhaine32865
              Allegedly, soaking a potato in glacial acetic acid converts it to soli cellulose acetate.
              More reliable could be Corian.  I have a local kitchen fitter who has loads of scrap, raid his skip.
              Edited By John Haine on 12/01/2023 12:25:33
              #628831
              Martin Connelly
                @martinconnelly55370
                I have used "Ivory 133" cast acrylic for a cosmetic ivory look.
                Martin C
                #628834
                Tim Stevens
                  @timstevens64731
                  There are many more suitable plastics now than there were in the 'good old days' – but butter knives are not made using it. Using ivory is frowned on, so anything that imitates ivory is frowned on just as hard.
                  But hope may be at hand. There is a 'hobby' which can help – making fancy pens. Axminster is one supplier that comes to mind – they are likely to have something that will meet your needs.
                  Cheers, Tim
                  #628835
                  Vic
                    @vic
                    Bit expensive but any good?
                    #628838
                    Brian Wood
                      @brianwood45127
                      Try the local charity shops, you might find some donor material.
                      #628839
                        Most of the wood turning suppliers do a modern resin form in various size pieces, Axminster, Poolewood, etc or look at "Where to buy" on GPS's site
                        #628844
                        Grindstone Cowboy
                          @grindstonecowboy
                          There is (or used to be) a product called Micarta, much used by the knife-making fraternity. Lots of different colours available if you wanted to move away from the traditional.
                          Rob
                          #628846
                          Bazyle
                            @bazyle
                            ALso check that it is 'dishwasher safe'
                            #628851
                            Clive Farrar
                              @clivefarrar90441
                              Tagua nuts ( seeds ) from the palm of the same name are known as vegetable ivory.
                              Seen them on ebay for £8 each I am sure there will be other sources.
                              However they will not be big enough to do a knife handle.
                              #628852
                              Jelly
                                @jelly
                                Posted by Chris Pearson 1 on 12/01/2023 11:58:59:
                                Don't need to, you can buy pre-prepared blanks of bone from suppliers to the cutlery trade.
                                SheffieldCutleryShop has a wide range of camel bone blanks.
                                #628854
                                Martin Kyte
                                  @martinkyte99762
                                  Axminster Tools stock it.
                                  regards Martin
                                  #628857
                                  Dalboy
                                    @dalboy
                                    Pen turning suppliers sell the Ivory substitute These are some but may be a little on the small diameter size there are others that sell bigger sizes
                                    #628865
                                    KWIL
                                      @kwil
                                      Thank you all.
                                      #628981
                                      Chris Pearson 1
                                        @chrispearson1
                                        Posted by Jelly on 12/01/2023 14:23:38:
                                        Ah yes, but in my experience (provided that you are buying some meat) bones are buckshee.
                                        #628991
                                        Dalboy
                                          @dalboy
                                          It is alright turning bone but if anything like turning antler then a nice day with the shed/workshop door open is advised and a fan blowing across the piece aiming at the open door. Boy does antler stink when being turned.
                                          #628998
                                          V8Eng
                                            @v8eng
                                            Knife Scales! Well I still learn something new here on a regular basis.
                                            #629496
                                            Calum
                                              @calumgalleitch87969
                                              Bone must be degreased before use; don't just get some big lumps from your butcher and wing it. Doing it properly at home is possible but tedious – you can't just give it a wash down and get on with it. The best approach is to buy it prepared, unless working with bone is your particular interest.
                                              I'd avoid the resin blanks you see advertised on eBay – they tend to be brittle and don't age well.
                                              The Corian stuff is good to work and cheap, but it's not really anything like ivory in appearance. It works well mechanically – it's often used for guitar nuts and saddles, for example.
                                              Two other well regarded makers are GPS (Guitar Parts something) who make several different excellent varieties in various forms, and Elforyn. Neither are very cheap, but machine and polish well and look very good indeed.
