Arceurotrade 000 QCTP
Home › Forums › Workshop Tools and Tooling › Arceurotrade 000 QCTP
  • #223678
    jim’
      @jim11037
      Treated meself to one of Arceurotrade's new 000 QCTP.
      These are the sliding wedge type.
      I bought mine for a Sieg C4, i'd had a mini lathe QCTP before, but, they are not very good!
      Very impressed! Very precise location, far more positive and accurate than my "piston" type 2 on the Crusader!
      Only problem is, I now need to buy more holders…….
      #17987
      jim’
        @jim11037
        #223681
        Muzzer
          @muzzer
          #223686
          John Rudd
            @johnrudd16576
            Posted by jim' on 02/02/2016 19:05:17:
            I bought one too, with the three holders plus two more…
            Cant wait to fit it….smiley
            #223690
            Hollowpoint
              @hollowpoint
              I saw them on the website. I wonder if they will be doing the larger 250-100 wedge type?
              #223692
              jim’
                @jim11037
                250-200 would be nice!
                #223693
                mark61
                  @mark61
                  I will certainly be buying the 250-100 wedge type and several holders if they become available.
                  #223694
                  Bazyle
                    @bazyle
                    I found the website rather short on the information needed to make a decision on the size needed for a particular lathe. However it is good to see the low priced versions of the wedge type have made it at last to this side of the pond.
                    #223725
                    Ketan Swali
                      @ketanswali79440
                      Posted by Bazyle on 02/02/2016 21:49:04:
                      Hi Bazyl,
                      You are right. Dimensions are provided by clicking on the Specification tab. However, beside the mini-lathe, no advice given for use on other lathes. This is a limitation which we are finding difficult to address for various reasons.
                      For example, according to the dimensions table, the stud in the middle of the 000 is 10 x 1.5mm trhread. it is a direct fit for mini-lathes which have the same size stud fitted to them. So reasonably easy retrofit for many people who have a mini-lathe with a 10×1.5mm thread stud.We dont know how much of a 'straight forward' fit this is for use on other lathes,….which is why we have given the dimensions, for a new buyer to review and ascertain its sutiability for their lathe. For some it may be a direct retrofit, and for others they may need to modify the stud and or add/change the packer below the post.
                      If and when we know for sure about a retrofit/suitability with or without modification for a different lathe, we may add the details to the 'more' section of that product.
                      Ketan at ARC.
