alinement of tailstock
Home › Forums › Beginners questions › alinement of tailstock
Viewing 25 posts - 1 through 25 (of 33 total)
  • #112529
    Lloyd Bowers
      @lloydbowers78291
      Hi all, been looking and trying to set my tail stock to be dead centre on my exe 3.5 super, ive managed to get it within a thou to two side to side (towards/away from operator) but its still a little high, at least 0.5mm which i think is 20 thou i think. I have a dial gauge but over the 10" its a little "wobbly"? so ive ran the gauge side to side a number of times to check.
      my question is is this high within tolerance? if not how can i adjust it, i think its level/parallel to the bed.
      #6587
      Lloyd Bowers
        @lloydbowers78291
        #112535
        Les Jones 1
          @lesjones1
          Hi Lioyd,
          Can you describe how you are checking the tailstock centre height in case the error could be in the method you are using rather than a real error.
          Les.
          #112538
          Bubble
            @bubble
            Hi Lloyd
            Put the lathe centres in the headstock spindle and tailstock, bring them together and insert a thin flat strip such as a Stanley knife blade between the points. Bring them in light contact. If the centres are in alignment the strip will remain vertical. If your tailstock really is .5mm out of alignment the strip will deflect. This test can be remarkably sensitive. The centre points must be in good condition, not bruised at all.
            Jim
            #112540
            Nobby
              @nobby
              Hi Lloyd
              How about putting a dti in chuck . slide talstock forward a lock . set the clock so you can rotate it around the barrel check front to back first for any error .. adjust tailstock then check top and bottom .
              Jims is a good method do that first , Also go on to Utube & have a look there.
              Nobby
              #112542
              Lloyd Bowers
                @lloydbowers78291
                hi all, thanks for the surgestions i think ive basicly done what you've said nobby but dont own a sensitive dti,  im just got a plunger type, so exspected a thou or two difference, i used a magnetic holder for my dial, which was fixed to the chuck then the dial on the revolving centre that i have, checked it first at the back face, then the front face (side to side) then turned it to the top and saw it was out compaired with the sides.
                I didnt do the outside of the quill incase the quill wasnt concentric. i done this close to the chuck first, then moved it back to about 10" where i need it for one bit im doing, i cant remember if both near and far were the same amound out?
                Edited By Lloyd Bowers on 19/02/2013 11:05:36
                #112544
                Les Jones 1
                  @lesjones1
                  Hi Lloyd,
                  Could it be that the 10" bar supporting the dial guage is flexing with the weight of the dial guage. When the dial gauge was above the quill it would sag causing a high reading. When it was below the quill the sag would cause a low reading.
                  Les.
                  #112546
                  Lloyd Bowers
                    @lloydbowers78291
                    yeah i did think of that, but i dont think it would be all that much, and there was a little near the chuck. im going to try a stiffer bigger bar to hold the gauge..
                    #112547
                    Lloyd Bowers
                      @lloydbowers78291
                      am i right in thinking high isnt as important as side/side?
                      #112548
                      Ady1
                        @ady1
                        Put two good pointy centres into the head and tailstock tapers and bring them together by eye
                        The headstock is the critical bit for workholding
                        I can't see you getting "true alignment" from a hobby lathe tailstock because it travels up and down the bed so some small errors will always arise
                        edit
                        Normally the pointy bits should show the same height and the only adjustment is from side to side
                        If the height is obviously wrong take it to bits and clean it up and have a good look at it
                        edit2
                        Don't forget that the tailstock barrel can be wonky/loose inside the tailstock housing, this is an old hobby lathe we're talking about and some errors you will have to accept and deal with as you do your metalwork
                        Edited By Ady1 on 19/02/2013 11:31:41
                        #112552
                        Lloyd Bowers
                          @lloydbowers78291
                          ok, thanks, will do and recheck.
                          #112557
                          Ady1
                            @ady1
                            Don't view your tailstock as a high precision part, more as an aid to workholding which needs to be as close as possible to the centre point of the headstock
                            If you're tailstock isn't well adjusted then it can break small drills because it isn't drilling straight down the centreline
                            If it drills a nice neat hole down the centreline when you have a workpiece in the chuck then that's all you can really expect of it
                            gl
                            #112558
                            speelwerk
                              @speelwerk
                              Make an arbor which you can place between the centers, as long as possible, solder on the ends a small length of larger diameter. When you turn, without changing the tool setting, the same diameter at headstock and tailstock end, your tailstock is in alignment. Niko
                              #112561
                              Nobby
                                @nobby
                                Hi Again
                                I have a mandrel I ground between centres approx 9" long . that I used to check my 2&1/2" exe lathe before cleaning up Nobby
                                . test
                                #112565
                                Lloyd Bowers
                                  @lloydbowers78291
                                  ok i see. thanks. ill try it and see. do you also double check the tool is centred at both ends before or after?
                                  #112606
                                  Lloyd Bowers
                                    @lloydbowers78291
                                    yep the bar worked, kind of? some how end to end was fine or ajustable to be fine. but the middle was slightly thicker? is that flex in the work piece due to the pressure of the tool acting on it?
                                    #112613
                                    Sub Mandrel
                                      @submandrel
                                      Most likely it is, unless the centre portion of the bed is worn.
                                      Nobby
                                        @nobby
                                        Hi
                                        A traveling steady would help Similar to this
                                        Nobby
                                        exe lathe
                                        #112626
                                        Ady1
                                          @ady1
                                          The centre/Chuck end of your bed is probbly worn to some extent
                                          The same probbly goes for your main leadscrew
                                          Your crosslide leadscrew is probbly the same, more wear in the middle
                                          You'll pick these things up as you get more experienced with your unit and fix or work your way around them, usually they are too minor to correct "for all time"
                                          What I ended up doing was only doing things accurately when it was essential
                                          Most of the time mega accuracy is unnecessary, your lathe will do a lot of hard work roughing stuff down, milling etc
                                          This knocks things about
                                          For any "final cuts" you get serious about accuracy, nipping up the slides etc
                                          The main thing is that your headstock bearings/spindle are decent, a wonky headstock is bad news
                                          Edited By Ady1 on 19/02/2013 22:11:15
                                          #112627
                                          Lloyd Bowers
                                            @lloydbowers78291
                                            Posted by Ady1 on 19/02/2013 22:05:34:
                                            i hope not. dont try to worry me with those possibilitessurprise.
                                            does the fixed steady fix to the cross slide?
                                            #112628
                                            Ady1
                                              @ady1
                                              The fixed steady goes on the lathe bed
                                              The travelling steady goes on the back of the cross slide saddle
                                              #112629
                                              speelwerk
                                                @speelwerk
                                                For checking the alignment of the tailstock it is not necessary to turn the bar the full length, just the tail- and headstock end is enough, that is why you solder on the ends a larger diameter with a length, of ca.15mm, so can you pas the full length without taking a cut. Niko.
                                                #112643
                                                Lloyd Bowers
                                                  @lloydbowers78291
                                                  Posted by Ady1 on 19/02/2013 22:18:44:
                                                  ok, got a fix steady which works well.
                                                  travel steady's, Isnt the saddle the bit that slides across that the tool post is bolted to? do you cut to depth then stop and adjust travel steady to suit, otherwise it'll move away when cutting into the work piece?
                                                  #112644
                                                  Lloyd Bowers
                                                    @lloydbowers78291
                                                    Posted by speelwerk on 19/02/2013 22:18:51:
                                                    yeah, i understood but didnt have the right sizes and kit etc at the time, it will be something i will make though. I guess i could mig 2 nut on to the bar?
                                                    Time is never kind when you have kids! indecision
                                                    Edited By Lloyd Bowers on 20/02/2013 08:45:04
                                                    Edited By Lloyd Bowers on 20/02/2013 08:45:40
                                                    #112661
                                                    Ady1
                                                      @ady1
                                                      It goes on the back of the saddle and avoids the cross slide movement
                                                      After each cut it does need to be adjusted
