Adept vise repair
Adept vise repair
Home › Forums › General Questions › Adept vise repair
  • #94515
    William Hulme
      @williamhulme24010
      I have aquired an Adept swivel machine vise with one mounting lug broken off.
      What repair method should I use? Carefully braze on a mild steel lug by means of good workshop practice (vee-ing out and preheating), Sending out to a specialist welding shop or attaching a sub base of say 6mm plate and fixing underneath with csk cap screws or is there a better fourth method?
      #22156
      William Hulme
        @williamhulme24010
        #95899
        Tim Stacey
          @timstacey83769
          Hi,
          You could make up a new base but that is probably not cost effective. The easiest is a sub plate underneath but it won't look the best. Welding or brazing will look the best but you have the distortion risk.
          I would say that it all depends how much effort you want to spend vs how you want the repair to look.
          Tim
          #95903
          Brian in OZ
            @brianinoz24148
            Hi William,
            Take it you mean bronze brazing, if so in a previous life i did quite a lot of cast iron repairs both with oxy and electric…there are some special rods (electric) for cast iron which along with good preparation and pre-heating/slow cooling produce a very good job..need a little grinding to tidy up the welds but otherwise quite acceptable….bronze brazing works too but you need a lot more pre-heating of the item and a good heat source ie oxy acetalyne…tried it with oxy/lp and heat input not so good…but depends on how thick the item is and how big as the rest of the item 'heatsinks' the heat away from the repair..
