A1999 Tumbler sleeve gear retaining screw H43
Home › Forums › Workshop Tools and Tooling › A1999 Tumbler sleeve gear retaining screw H43
  • #156344
    Dazzamatazz
      @dazzamatazz
      I have had the A1999 Tumbler sleeve gear retaining screw H43 shear on my Myford Super 7. I have had 2 new ones supplied by Myford this week and both are to big the TPI is correct at 32 but the diameter is to large. Does anyone know the correct size. My lathe was build between 1991-1994.
      Regards Darren
      #17426
      Dazzamatazz
        @dazzamatazz
        #156349
        Brian Wood
          @brianwood45127
          Hello Darren,
          I'm surprised Myford have supplied you with oversize parts [twice from what you say]
          The screw thread is 2BA which isn't far from 32tpi but is actually 31.36 tpi and easy to mix up.
          Try a 2BA screw instead.
          Regards Brian
          #156361
          Mike Poole
            @mikepoole82104
            10×32 UNF, M5x0.8 and 2BA are all very close to each other, tricky when sorting the mixed useful fastener tin.
            #156372
            Dazzamatazz
              @dazzamatazz
              I have had a check this morning after arriving at work we have no BA nuts and bolts but i have tried 10×32 unf and 5mm.
              I can get a 10×32 unf nut to run up the old broken part with no play and a 5mm nut will run up the new parts supplied by Myford.
              I will try a 10×32 unf bolt when i get home.
              Regards Darren
              #156373
                Posted by Michael Poole on 26/06/2014 22:58:51:
                Too true !!
                Unless you happen to have some proper thread gauges to hand; it's worth tapping a set of holes side-by-side in a plate, and marking these for reference. Keep the plate in or near that tin.
                Dazzamatazz
                  @dazzamatazz
                  Myford asked for the model and year of the lathe yesterday morning and I have not heard from them since.
                  10×32 unf bolt did not fit so I do not know what size it is.
                  I tool the tumbler reverse of the lathe and drilled and tapped it to 5mm.
                  Now the lathe is up and running again.
