A radiator valve question
Home › Forums › The Tea Room › A radiator valve question
  • #344286
    Robin Graham
      @robingraham42208
      Because of the dire weather I turned on our bedroom radiator t'other night – I don't suppose it's been used more than two or three times in the last three years. It's one of those old simple screw valve jobs, not thermostatic. It's started leaking from under the cowl on the knob, so I guess it's a problem with a sealing gland.
      Does anyone know of a cunning way of fixing this without draining down the (pressurised) system? I have a dim memory of a method involving freezing the pipe below the valve, but have never tried it.
      Robin.
      #35129
      Robin Graham
        @robingraham42208
        #344287
        Phil Francis 1
          @philfrancis1
          You should be able to just tighten the gland nut. Phil
          #344289
          Muzzer
            @muzzer
            If you remove the knob you should be able to tighten the gland nut that is hidden under it. It squashes down on the gland washer / o-ring. No need to drain anything.
            If the worst comes to the worst, draining down a pressurised system isn't difficult. The volume of water involved is less than for a header tank (unpressurised) system.
            Those freezer systems sort of work but are an expensive way to do the job.
            Murray
            #344296
            Speedy Builder5
              @speedybuilder5
              If per chance you have to drain down, don't forget to add anti corrosion liquid when you re-fill. best done by a funnel and a tube in one of the upstairs rads by removing the air valve and putting it in there. Something like "Fernox" ?
              BobH
              #344300
              Redsetter
                @redsetter
                Most modern radiator valves do not have an adjustable gland nut. When they start leaking you have to replace them.
                #344306
                Don Cox
                  @doncox80133
                  Mine's a sundial Y plan system with a header tank, so not pressurised (much). Any time I've needed to do jobs of this type I minimise the amount of water drained down by putting a cork in the header tank outlet and locking off all the radiators by shutting down both valves. The amount of water drained from the pipework then 3/4 fills a 2 gallon bucket. I usually return this to the roof tank to preserve the inhibitor content. I can also vouch for the effectiveness of an Adey Magnaclean, which in addition to filtering out any ferrous debris etc also allows for an annual addition of Sentinal X100 direct into the system, with any left overs added to the header tank.
                  Don Cox
                  #344314
                  Sam Longley 1
                    @samlongley1
                    When you drain down you will still get a bit of water out of the rad so a wet & dry vacuum cleaner hose held under the pipe whilst you slowly undo it does help to catch most of the water. Be aware that Fernox in the system will rot the carpet over time so be careful of spillage
                    #344327
                    Brian Wood
                      @brianwood45127
                      I have used the freezing kits to good effect with soldering in new sections of pipe; I suspect the dissatisfaction expressed earlier was down to rushing the job and not letting a proper ice plug develop in the pipe.
                      I don't think I am breaking any national secrets by saying that a variation of the method is applied to nuclear submarine repairs, using liquid CO2 as the freezing agent. This is a dockyard job to replace components such as a faulty valve in the reactor system, for those operations they install a manned watch to be quite certain a leak in the primary circuit does not take place.
                      The rest of the system is still kept pressurised for reactor cooling purposes to about 1200 psi and close to 180 degrees centigrade. The ice plug itself is maybe 12 to 15 inches long in these jobs
                      These repairs are carried out on thick walled stainless steel piping of about 1 inch wall section and the new components are welded into the circuit; all a very far cry away from domestic operations in copper pipe
                      Brian.
                      #344455
                      Robin Graham
                        @robingraham42208
                        Thanks. There's no obvious way of getting the plastic knob off the valve to expose the innards, which is why I thought i'd have to replace the whole thing. .. Maybe I'll chisel it off and see!
                        Otherwise I guess I'll have to drain the system and fit a new valve- probably overdue anyway.
                        Robin
                        #344458
                        Grindstone Cowboy
                          @grindstonecowboy
                          The plastic knob should just pull of, although I have seen them with a screw in the top that has to be removed first – this might be hidden under a glued-on ali disc.
                          #344459
                          bricky
                            @bricky
                            I as suggested seal the header overflow with a 20mm push fit fitting then using a seling kit which is conical rubber bung inserted into the header tank outlet you will create a vacume ,and using a black bin liner fitted around the valve relese the nut and there will be about 1ltr of water which will drain into the liner do not open the bleed valve.You will be able to remove the valve and replace if neccessary.Nerves of steel required.
                            Frank
                            #344612
                            Robin Graham
                              @robingraham42208
                              Posted by Rob Rimmer on 05/03/2018 00:16:34:
                              The plastic knob should just pull off
                              Oh dear – spot on. Didn't think of that blush. Stupidity I suppose! There was indeed a much crudded-up nut underneath, which I have tightened . Thanks – I'd have been pretty sick if I'd got a plumber in, seen him pull the cap off, put on an eighth turn on the nut then charge me 50 quid.
                              Frank – your method sounds scary! Not sure if I even have a header tank – I thought combi boilers just took water from the main supply without any ancillary gubbins, but plumbing is dark mystery to me, so maybe there is one somewhere…
                              Robin
