I need to make some taper plug cocks for my large steam engine and am wondering what sort of taper to use. Obviously too fine and it will jamb. I was wondering about using a taper pin reamer that has a 1/48 taper. Would this be too fine?
Gosh, that looks superb. Excellent suggestion Jason about cutting the plug and a D reamer on the same setting. Just a question about the D reamer, I guess that you used reasonable hard steel but did you heat treat it?
