Brass taper plug cock dimensions
Home › Forums › Beginners questions › Brass taper plug cock dimensions
  • #397316
    David Hill 5
      @davidhill5
      I need to make some taper plug cocks for my large steam engine and am wondering what sort of taper to use. Obviously too fine and it will jamb. I was wondering about using a taper pin reamer that has a 1/48 taper. Would this be too fine?
      Thanks for any help.
      David
      #9543
      David Hill 5
        @davidhill5
        #397318
          I think around 7-10degrees included angle would be better, your 1:48 will tend to lock.
          best to make a taper reamer at the same setting when you turn the spindles
          #397325
          Maurice Cox 1
            @mauricecox1
            Jason; I do like the look of your taper plug cock! Is the body a casting, filed/milled from solid or two pieces silver soldered together?
            Maurice.
            #397330
              Cut from a bit of 5/8" square, I did later solder on the threaded drain pipe connection
              #397341
              David Hill 5
                @davidhill5
                Gosh, that looks superb. Excellent suggestion Jason about cutting the plug and a D reamer on the same setting. Just a question about the D reamer, I guess that you used reasonable hard steel but did you heat treat it?
                David
                #397350
                Brian H
                  @brianh50089
                  Magic! They look good Jason and by chance I have to make a pair myself, but without the drain pipe connection.
                  #397353
                    Silver steel, hardened but did not bother to temper.
                    #397364
                    David Hill 5
                      @davidhill5
                      Great, thanks Jason.
                      David
