Colbalt Lathe tools
Colbalt Lathe tools
Home Forums Beginners questions Colbalt Lathe tools
  • #9446
    Dalboy
      @dalboy
      #385651
      Dalboy
        @dalboy
        In my odd bits I have two Cobalt tools steels for the lathe I know about HSS.
        Are they good and what metals would they be used on and what type of finish would you expect to get off of them
        #385654
        Vic
          @vic
          I have some HSS toolbits that say 5% or 8% cobalt. If this is what you have it’s just one of many grades of HSS that are available.
          I recently bought an M42 HSS wood turning gouge as it was supposed to be a lot better in terms of sharpness and longevity of the edge but I can’t see it’s any better so far.
          #385655
          Russell Eberhardt
            @russelleberhardt48058
            Those tools are not likely to be cobalt but a grade of HSS that contains cobalt such as M42. A somewhat superior grade of HSS. It has better high temperature performance than the other grades and can work well when red hot.  Not likely to be important in the home workshop!
            Russell
            Edited By Russell Eberhardt on 14/12/2018 14:48:54
            #385657
              Posted by Vic on 14/12/2018 14:44:00:
              That's a handy reference document … Thanks, Vic yes
              Ady1
                @ady1
                Cobalt holds its edge better at low speed and is not prone to chipping, very tough in the right circumstances
                It's the go-to tool if using a shaper or carving tough material on a lathes backgear, you do far less resharpening than with standard hss
                At higher speeds carbide is king, hss isn't even close, even cobalt hss doesn't perform any better than hss once the speed and grinding action ramps up
                Each material has its merits
                #385668
                Dalboy
                  @dalboy
                  Thank you all for the information so they are well worth keeping. They are 3/8" square X 3" long.
                  #385755
                  Ian S C
                    @iansc
                    HSS wood lathe tools have a great advantage over carbon steel when it comes to sharpening, you don't draw the temper if you get the edge just a little warm. I feel that a well sharpened carbon steel skew chisel, scraper, or gouge cuts better than HSS, but the HSS holds the edge it has longer.
                    Ian S C
                    #385812
                    Dalboy
                      @dalboy
                      Posted by Ian S C on 15/12/2018 11:17:44:
                      Ian S C
                      I agree unless you are turning well seasoned Oak
                      #385827
                      Vic
                        @vic
                        Some may find this of interest.
                        Carbon steel make good finishing scrapers for woodturning if you can find them.
                        #385831
                        Mick B1
                          @mickb1
                          My father-in-law gave me 2 pieces of 1/2" square Cobalt HSS in 1975. I ground one of them to a 55 degree screwcutting tool. I have to admit that my use of it has been highly intermittent, but I've only recently reground it for the first time, after doing some 1" x 8 TPI threads about 6" long for locomotive superheater header bolts.
                          Use it at reasonable cutting speeds, and it could last a lifetime – though I suspect the basic quality of the HSS might be as important as the cobalt… thinking
                          #385923
                          ega
                            @ega
                            Posted by Vic on 15/12/2018 18:58:37:
                            Thanks for the link. The Eccentric Engineer over on the right is a fan of cast alloy.
                            Woodturning scrapers were traditionally made from worn out files, of course (use with care!).
                            #385925
                            ega
                              @ega
                              PS duplicate post caused by using back button – sorry!
                              Edited By ega on 16/12/2018 11:01:36
                              #385936
                              Dalboy
                                @dalboy
                                Posted by ega on 16/12/2018 10:59:58:
                                Files as scrapers are just to brittle to be used as scrapers unless someone is in the know on how to go through the reheating to make them safe they are best avoided. I know turners of old use to use them but people new to the hobby are always told to avoid them as that is where most accidents happen
                                Edited By Derek Lane 2 on 16/12/2018 11:47:01
                                #385956
                                ega
                                  @ega
                                  Posted by Derek Lane 2 on 16/12/2018 11:46:29:
                                  As MEs we certainly ought to be capable of applying suitable heat treatment; with or without, it helps if the file concerned is a thick one and the woodturner is not!
                                  #385966
                                  Dalboy
                                    @dalboy
                                    Posted by ega on 16/12/2018 13:03:43:
                                    My answer above was about scrapers in woodturning
                                    Yes but tell a woodturner who is new to the hobby that it is unsafe he or she will not be aware of the problems until informed.
                                    I do a lot of woodturning as can be seen HERE and am fully aware of the problems How many Model Engineers do wood turning that would have the need to make a scraper for that purpose not many I should think.
                                    #385970
                                    clogs
                                      @clogs
                                      as well as wood turning tools have a few metal files (at least 6) that have been reused as cold chisels ….
                                      u can see where they have been heated and reshaped……..
                                      mine have not chipped and hold a good edge…….these were given to me by some old guy…..who's no longer with us……but I do thik of him when I used said chisels…….
