Lathe turning tool nomenclature
Home › Forums › Workshop Tools and Tooling › Lathe turning tool nomenclature
  • #868778
    JA
      @ja
      Once upon a time a “left hand knife” turning tool cut towards the lathe head stock (ref: Myford Series 7 Manual by Ian Bradley). Now Myford supply insert holder for cutting towards the head stock as “right hand”. Why the change or is it just to confuse old people like me?
      JA
      #868784
        I have always termed a L/H tool as one that cuts from left to right, so insert holders are no different. mybe Mr Bradley is to blame
        Harrold Hall has it as I learnt at school
        hand
        #868800
        Bill Phinn
          @billphinn90025
          This was puzzling to me as well once.
          Just remove your focus from the direction the angled tip points in and consider only the direction it cuts from relative to the operator. Then all will become clear.
          The handedness of boring tools follows the same pattern as long as we assume (which I think we safely can do) that the operator uses them whilst facing the chuck rather than looking across the bed as in the first case.
          #868801
          JA
            @ja
            I have just dig out my copy of Sparey’s “The Amateur’s Lathe”, first published in 1948. He clearly says a left hand knife tools cuts towards the headstock. I am no longer going to look for my apprentice notes.
            JA
            #868812
            Bill Phinn
              @billphinn90025
              I’m looking at a copy of Sparey now. On page 77, in figure 63, he shows a drawing of an HSS turning tool that today would be universally described as a right-hand tool. His description says: “The illustration shows a right-handed tool for cutting towards the chuck”.
              I can only assume there must be different editions of Sparey saying different things on this subject.
              #868813
                You must have a different edition of Sparey than me JA
                rhOn page 77 it clearly shows and stated a R/H too cutting TOWARDS the chuck
                #868817
                Roderick Jenkins
                  @roderickjenkins93242
                  My edition of the Bradley Myford series 7 manual says this:
                  bradley s7 manual rh tool
                  Rod
                  #868818
                  ega
                    @ega
                    An analogy from woodturning might help: imagine the turner working a skew chisel towards the headstock – his right hand naturally grips the blade and the reverse is true for the other direction.
                    #868828
                    DC31k
                      @dc31k
                      That might not be a good analogy as with a woodturning tool, BOTH hands are involved in its use.
                      It is only by convention that (if what you say is correct) we hand the tool by the one that touches the steel part and not the one that touches the wooden handle.
                      One could draw an equally poor analogy with guitars: they come in both left and right handed, but the defining one is the one that does the strumming not the one that frets the notes.
                      #868849
                      JA
                        @ja
                        JA
                        Sorry. I messed up my reply. I should have said right hand.
                        Humble pie.
                        JA
                        #868858
                        old mart
                          @oldmart
                          I have always known a right handed lathe tool to be normally used to face off the right side of the workpiece, and vice versa for the left tools.
                          #868906
                          JohnF
                            @johnf59703
                            Right hand cuts from right to left  — left hand cuts from left to right ! simples !
