Moving a Chester MF42Bb(removing milling tool)
Home Forums Introduce Yourself – New members start here! Moving a Chester MF42Bb(removing milling tool)
  • #853203
    bowmandj1953
      @bowmandj1953
      Hi I’m derrick and, having now retired, want to resume my hobby of model making and hobby engineering. To this end I’ve just taken possession of a Chester MF42B lathe from a relative who has recently passed away.
      But I need to move it to my workshop.
      It weighs 180kg, so to move it I’ve removed the tail stock, tool post and carriage, chuck and motor. But I need to remove the milling tool.
      Any advice on removing the milling tool please. I cannot find any bolts that clearly locate it. And if I do does it just slide up?
      Where it is currently located is in a cramped shed with no room for a beam or engine hoist. Thanks
      #853229
      Adrian R2
        @adrianr2
        Is it this one? Looks like head is on a big screw thread, wind it up a bit and look for bolts underneath?
        https://www.chesterhobbystore.com/wp-content/uploads/2020/11/MODEL-B-MANUAL-NEW-2011.pdf
        #853234
          This is essentially the same as a Clarke CL500M.
          You can download a manual here https://www.clarkeservice.co.uk/manuals/metal_lathes/CL430_Metal_Lathe_REV_3.pdf
          That link may trigger a security warning, but it’s just and expired security certificate and the PDF is clean.
          The square slab on top of the headstock (somewhat thinner on the Clarke version) should be held in place by four cap screws (see page 10).
          bowmandj1953
            @bowmandj1953
            Thanks Adrian. It is that one. I’ll try what you say but I better make a tripod hoist first. I’ll have to lift it above my neck height and that could be precarious without a hoist to stabilise the weight.
            #853255
            bowmandj1953
              @bowmandj1953
              Thanks Neil. That Clarkson manual gives me what need. The installation from new.
              cheers.
