Help with a collect chuck
Home › Forums › Workshop Tools and Tooling › Help with a collect chuck
  • #832235
    ian Holdsworth
      @ianholdsworth27760
      I have purchased some second hand tools. In them is a Milling machine collect chuck.
      There are a number of different collects and are interchangeable, well they would be if I could extract the existing collect! It has a large lipped washer in the chuck body. It is fixed and locates on the grove in each collect. How do I extract and change the collect. Photos herewith. Do you know how to do this or the manufacturer of the chuck?
      10000330131000033014
      #832238
        You need to tilt the collet to one side then it should snap out
        MFB A2
        #832241
        Ian Parkin
          @ianparkin39383
          just grasp the collet and twist it to one side axially then it should fall out..when its out you will see how it fits
          #832249
          noel shelley
            @noelshelley55608
            It’s of the ER type, in this case an ER25, Jason has shown how it works.  Noel.
            #832255
            bernard towers
              @bernardtowers37738
              Bearing in mind that the nut needs to be twisted at the same time to get to the position that allows the collet to release easily.
              #832262
              old mart
                @oldmart
                Press the collet in every direction until it tips and then you drop it. The collets must be snapped into place before screwing the head on the arbor.
                #832264
                jimmy b
                  @jimmyb
                  I’ve lost count of how many times a tool problem turned out to be a collet NOT fitted properly to the nut….
                  Jimb
                  #832266
                  Diogenes
                    @diogenes
                    If not clear from above replies, the hole in the washer is eccentric – you might be able to see which is the ‘low’ side by looking inside..
                    #832268
                      The usual first-encounter problem with ER collets is failing to click them properly into place during installation.   Jason’s diagram shows the collet and tightening ring are both removed from the chuck to do this.  Stage A shows the collet goes in at an angle and pops into place.  You can’t just drop the collet straight into the ring and have it click correctly into position when the ring is tightened in the chuck.
                      As Jason explains, removing is the reverse: the collet is popped out by tilting and pushing, as shown in Stage C.
                      Easy when you know how, but not obvious.   Some do it intuitively.  Had me confused for about 10 minutes before I twigged.  Others have to ask.
                      Bonus hint. ER tightening rings come in two forms.   The rings fitted with a ball-bearing are easier to tighten and undo: worth buying.
                        As I mentioned in a thread a few weeks ago about ER Collets, if you mark your nuts where the eccentric lip is closest to the hole you don’t need to waste time rotating to try and find the spot where the collet tilts. Just tilt towards the mark whether inserting or removing. This 6mm ER32 snaps in & out easy enough when you know which way to tilt it.
                        #832280
                        John Haine
                          @johnhaine32865
                          <p style=”text-align: left;”>Dave I assume that by tightening ring you mean nut?</p>
                          #832285
                          ian Holdsworth
                            @ianholdsworth27760
                            Thanks. All is well and I have iy out and a different one in. Thanks so much for the help!!
                            #832297
                            old mart
                              @oldmart
                              It will seem so easy once you have got the things clicking in and out.
                              I bought a couple of the ball bearing nuts which are first choice for er collets, only they have to be turned further to take up the slack.
                              When changing any size er collet tool in a vertical mill, it pays to have a cloth catcher under the endmill or drill, they can fall out of the collet and chip on the bed or even bounce onto the floor.
                              #832300
                                I do, sorry about that – I’m not on top form and misremembered the name.
                                Macolm
                                  @macolm
                                  When fitted correctly to the nut, the collet will loose enough to be rotated in the nut without resistance.
                                  #832361
                                  John Haine
                                    @johnhaine32865
                                    When I bought my s/h Novamill, ex-school, the last user (I suspect the teacher) hadn’t fitted an ER16 collet correctly so it wasn’t fitted in the eccentric ring.  Then he’d tightened the nut until it finally gripped, then probably found out that he couldn’t change the tool and left it like that.  I doubt his pupils got much useful instruction!  It was the devil’s own job to remove the nut and collet.
