Plain bearing play
Plain bearing play
Home Forums Beginners questions Plain bearing play
  • #801604
    Sonic Escape
      @sonicescape38234
      I disassembled the headstock of an Emcomat 7 lathe and I found a plain bearing that I think is worn out. As you can see in the video it has a significant play. I have no experience with plain bearings but to me it doesn’t look right. This is the arbor where the motor belt ends. So it can’t cause any loss of accuracy. But it will not make more noise than a tighter fit?
      #801624
      jamesp1
        @jamesp1
        Its hard to tell from the video because the shaft is moving around a lot. But it does look to have a few hundredths of a mm of movement there. It could be better but for a pulley shaft it is probably not critical. Probably not particularly noisy. But it looks like it could be a good first project when you get the lathe going, to make a bushing for itself from some leaded bronze. A nice little exercise in turning and boring with some useful outcome at the end.
        #801643
          Question is: Was the movement on the shaft or within the housing?  If only in the housing, it could be that the bush must be tightened after the shaft is fitted and aligned, so that the housing then clamps the bush in place.
          #801654
          bernard towers
            @bernardtowers37738
            wobbling a bush about like that does not tell you anything about the play when installed
            #801705
            Sonic Escape
              @sonicescape38234
              I’m not sure that I understood what you mean by “bush must be tightened”. You are referring to a split bush?
              This is what I have:
              Yes that is true. The bush is also easily accessible once the headstock is assembled.
              #801726
              HOWARDT
                @howardt
                Look at the Oilte catalogue for correct mounting dimensions and press fit with the correct bore pin diameter.  Before fitting if the bush is dry soak in the recommended oil overnight.
                #801732
                  No.
                  #801781
                  bernard towers
                    @bernardtowers37738
                    To lube its a bit better to block up one end and fill with oil then push with thumb and the lube should come through the wall of the bush filling all the gaps with lube.
