Twin wobbler engine
Twin wobbler engine
Home Forums Beginners questions Twin wobbler engine
  • #198466
    Mike Brett
      @mikebrett89695
      Hi all
      Having built a single acting wobbler engine that worked a treat I have just finished a twine cylinder single acting version, but alas this is not working. It attempts to turn under air pressure but as the pistons are at the midway point they are both being pushed at once and so they jam. I drilled the ports using the same method as the single version, that is when the cylinder was at the peak of its arc travel in both directions. The crank shaft is 180 deg. apposed to each other, so I am not sure what I have done wrong. Obviously the timing is out somewhere but how or what is the best way to alter it.
      #7725
      Mike Brett
        @mikebrett89695
        None starting wobbler
        #198467
        John Rudd
          @johnrudd16576
          I think your problem is the fact that you have a 180 degree crank….
          Most twins I know have the throws 90 degrees apart…..
          #198468
          Jeff Dayman
            @jeffdayman43397
            +1 on John's thoughts, if the ports are drilled right, a 90 degree crank timing rather than 180 deg will probably enable self starting. JD
            #198470
            Vic
              @vic
              I can't add anything but can I ask, if it was a flat twin presumably it would it have a 180 crank?
              #198475
              Mike Brett
                @mikebrett89695
                Hi
                Not sure what you mean by flat twine, but it is a horizontal engine with the cylinders side by side. Before I attempt any alterations I will try and post some pictures of it so that you can see the arrangement. If I have to alter the crankshaft it should be possible as its built from separate pieces pushed together using Loctite.
                #198479
                David Clark 13
                  @davidclark13
                  Try running it with one cylinder only. If it works it will be crankshaft position.
                  #198482
                  Mike Brett
                    @mikebrett89695
                    #198483
                    Mike Brett
                      @mikebrett89695
                      #198484
                      Mike Brett
                        @mikebrett89695
                        #198485
                        Mike Brett
                          @mikebrett89695
                          #198486
                          Jeff Dayman
                            @jeffdayman43397
                            Vic – you may be thinking flat twin as in BMW gasoline motorcycle engines. They do have 180 deg cranks. But a STEAM engine built with 180 deg crank, whether a flat twin or inline twin, will have a dead centre position where no port or both ports are open to pressure. If the crank is a 90 degree one, there is never a state where both ports are at the same open or exhaust state. If each cylinder's port is always at a different state to the other the engine will self start. V twin wobblers using a common crank pin are self starting because the ports on each cylinder can not be at the same state due to the V angle. JD
                            #198487
                            Jeff Dayman
                              @jeffdayman43397
                              Nice looking engine Mike! great job. I think if you reposition the cranks at 90 dge it will be OK, as long as the ports line up correctly as I originally mentioned.
                              You may get smoother running (once it is running) if the steam supply is midway between cylinders rather than teed as you have it.
                              #198490
                              Mike Brett
                                @mikebrett89695
                                Many thanks folks, I will alter the crankshaft and get back to you in due course with the results.
                                Cheers Mike
                                #198492
                                Gas_mantle.
                                  @gas_mantle
                                  Hope you get it going, it sure is a monster size wobbler
                                  Just as a matter of interest what size bore and stroke is it ?
                                  Peter.
                                  #198493
                                  Nick Hughes
                                    @nickhughes97026
                                    Looks to me that you have the air feed crossed. Just move one side to its opposite port, (so that both sides are fed either in each top or each bottom port, but both sides must be the same).
                                    The 90 deg crank is only for self starting (and you'll still need to alter the feed as above).
                                    Nick.
                                    Edited By Nick Hughes on 30/07/2015 16:55:14
                                    #198498
                                    john carruthers
                                      @johncarruthers46255
                                      As Nick says, check out the port arrangement on Elmer's 'H' twin;
                                      Edited By john carruthers on 30/07/2015 17:07:48
                                      #198505
                                      Mike Brett
                                        @mikebrett89695
                                        Hi
                                        Bore is 7/8 and stroke is 2 inches. If its just a case of moving the pipe that would be great, watch this space.
                                        #198513
                                          No! Don't alter the crank!
                                          As you said in your first post, that's a single acting twin engine so 180 degrees is right.
                                          A double acting engine needs 90-degree cranks, but that isn't one. A 90 degree crank won't solve the problem and when you do sort it, the engine won't run as well.
                                          The cylinders are positioned facing each other, so if made identically they will be be trying to run in opposite directions. Imagine turning to clocks to face each other – they both run 'clockwise' but their hands don't go the same way.
                                          The answer is as has been mentioned already is to swap over the steam and exhaust for ONE cylinder.
                                          John Rudd
                                            @johnrudd16576
                                            Posted by Neil Wyatt on 30/07/2015 18:18:48:
                                            Agreed, I missed the way the piping was arranged….my mistake…. Oops!
                                            #198574
                                            Mike Brett
                                              @mikebrett89695
                                              Hi again
                                              Well I swapped over the pipe on one side of the engine and that was the problem, it now works fine, very smooth even down to low speeds. With hindsight looking at the connections now it was a silly mistake to make, we live and learn. Many thanks to you all.
                                              #198580
                                              Gas_mantle.
                                                @gas_mantle
                                                Glad you got it going Mike, any chance we could see it running ?
                                                #198590
                                                John Rudd
                                                  @johnrudd16576
                                                  Glad you got it sorted despite the quality of advice….( guilty as charged…blush)
                                                  And didn't require any major rework….
                                                  #198626
                                                  Jeff Dayman
                                                    @jeffdayman43397
                                                    +1 to John's OOPS! – sorry, I missed the piping issue as well. Good catch Neil.
                                                    Glad you have it running now Mike. JD
