Why on earth did I do that…
Home Forums Beginners questions Why on earth did I do that…
  • #197083
    Brian Abbott
      @brianabbott67793
      Drawing reads drill #29 x 1 1/8 dp
      So I check on the chart and a #29 drill is 3.45' so why on earth do I then drill a 4.2 hole…
      need to wake up a bit me thinks…
      #7704
      Brian Abbott
        @brianabbott67793
        #197087
        Muzzer
          @muzzer
          Was that the final finishing touch on a years long project? I get more nervous the more work I put into something! Fill it up and redrill?
          #197105
          David Colwill
            @davidcolwill19261
            Known in the trade as a brain fart!
            (not that I've ever done one) crying 2
            #197116
            Robbo
              @robbo
              If it were me ( and it has been) it would be down to old age, eg too much activity asked of a diminishing number of brain cells.frown
              #197123
              jason udall
                @jasonudall57142
                Shit happens.
                No claret or fingers on floor. .no harm
                Try to not repeat the experiment
                Edited By jason udall on 18/07/2015 09:54:50
                #197185
                mark costello 1
                  @markcostello1
                  Worse than a brain fart, it messed up the mental diaper in the bed wink.
                  #197460
                  Dave Halford
                    @davehalford22513
                    Might make an interesting thread.
                    Whyoh why did I use a random cast iron welding rod that I'd had for 20 years to try a tooth repair on my rockwell 10" back gear. And why did I then compound the issue by using my rare as hens teeth new 16dp 20pa gear cutter on said welding.
                    What i ended up with is weld that will just about file and very nearly as hard as witches what'its and a Very, Very blunt cutter that i need to grind 2mm off to get right.
                    Sob !!!
                    #197466
                    Jesse Hancock 1
                      @jessehancock1
                      I've got a lot of tee shirts with Oooops written on them.
                      Using a few barbell weight's as stock for some sprockets. Got to the point where the tool hit the lettering and knocked the tip off! Resharpen and next onto the Vertex in junction with a Laser to mark out…. Last mark ugh ohh too narrow and I don't have a dividing head. Mmmm
                      Edited By Jesse Hancock 1 on 21/07/2015 12:25:16
                      #197492
                      OuBallie
                        @ouballie
                        Use the pein (peen) end of a ball pein hammer to knock off filler used on my 1935 Austin Seven, and now have a few perfectly round projections to knock back later, all on a visible rear quarter panel.
                        Geoff – Stupid or what?
