source of diy protective ‘rubber’ film for mills/ drills?
Home Forums General Questions source of diy protective ‘rubber’ film for mills/ drills?
  • #698383
    jon hill 3
      @jonhill3
      I recently grabbed a joblot of end mills and slot drills without their original boxes and was wondering if it is possible to source the rubber protective film that sometimes comes with new slot drills & endmills.
      Currently the lot is rattling around in a tin, not the best for precision cutting tools.
      If anyone knows of a source of such protective dipping rubber I would be very greatful…
      #698386
      DC31k
        @dc31k
        The stuff is called Crocell.
        You also need a means of melting it.
        Sit down before you look at the price.
        #698387
        noel shelley
          @noelshelley55608
          I seem to think it was called peelable grease, but that was not a trade name.  Noel.
          #698388
          peak4
            @peak4
            You can get a hot dip waxy stuff like Seba Protecta-Coat
            or alternatively I wonder if the sort of plastic used for plier handles etc might do a more permanent job; PlastiDip is one type.
            Bill
            #698413
            Nigel Graham 2
              @nigelgraham2
              Is this for long-term storage or do you want ready access to the cutters for use? For the latter, you don’t want the melt-on stuff.
              Polythene tube sleeves can be used to protect the cutting edges; lubricating-oil or grease inc. petroleum jelly (‘Vaseline’), or lanolin, will protect the steel from rusting.
              Wipe the shank clean before fitting it in the collet – for a screwed-shank cutter ensure the protective has not also stuck dirt into the thread.
              #698414
              peak4
                @peak4
                I forgot to mention, There is also this sort of protective meshing, which you could maybe colour code for metric/imperial 2/3/4 flute etc.
                I’ve no connection with this firm, or used their products
                image_2023-12-09_221612884
                Bill
                #698418
                Grindstone Cowboy
                  @grindstonecowboy
                  Crocell easily found on Ebay, but as DC31K says, not exactly cheap.
                  Rob
                  #698438
                  Diogenes
                    @diogenes
                    ..wrap a piece of oiled acid-free tissue round them, store them in a plastic organiser box.. ..?
                    ..pretty sure that job-lots of empty boxes turn up on Ebay now and again, I guess when CNC apprentices have their ‘practical’ week..
                    #698457
                    Ian Parkin
                      @ianparkin39383
                      I store my smaller and valuable bits in freezer trays for making ice sticks…silicone rubber and quite cheap
                      #698470
                      John Doe 2
                        @johndoe2
                        How about dipping them in melted candle wax? As long as they don’t get bashed around too much in their storage, that should be OK, and very cheap and easy !
                        Might need several dips to build up a reasonable layer.
                        Just be very careful if melting wax over an open flame, gasses can be given off which can ignite.
                        #698481
                          Two parts to this. One is mechanical protection and the other part is rust protection.
                          For the latter never use a paper product as it will eventually lose its protective juices, even raw oil, absorb moisture and promote rust. Clear Waxoil car underbody treatment is convenient and evaportates to a thin wax film. Hot wax is awkward and chips. If your church has 7 day candles in plastic tubes burning continuously ask for some spent ones. The small amount of wax left in each is a soft paste (the beeswax ones are rather firmer though.
                          For the mechanical part recover the 2litre milk bottle from your recycling. Cut off the handle including the curved bit at the top. A small mill fits in this and the curve stops it falling out the other end. Cut off the bottom of the bottle 1 in high as a tray. Cut the flat section in the middle that has the label on it into one long sheet and roll it up. Tie it thus and pop  it into some hot water, (experiment needed) to set it in this shape. Then you can cut sections of it to make tubes to stop the mills touching in the earlier mentioned tray.
                          #698483
                          Tony Pratt 1
                            @tonypratt1
                            Rob
                            Bill
                            I would go for the above ‘mesh’, Crocell isn’t really practical for cutters you are using on a daily basis.
                            Tony
                            #698503
                            jon hill 3
                              @jonhill3
                              Thanks guys, I dont think Crocell is that expensive after all I will probably need is a kilo bar and a suitable hotplate if I go done that route. I would imagine a little goes a long way, and very hand for reamers and slot drills.  Of the latter I have too many that I can use so will probably sell or swap for other useful things.
                              Can anyone recommend a suitable hotplate that can be found 2nd hand for cheap?
                              I like the mesh and sleeve ideas too.
                              #698505
                              Zan
                                @zan
                                Bond 2 layers of white covered chipboard from eg an old kitchen unit
                                drill a grid of holes to match the shank sizes
                                mark in pencil the mill diameter
                                easey safe Storage and identification
                                #698507
                                Zan
                                  @zan
                                  drill a grid of holes to match the shank sizes  or diameter of mill if putting in current down
                                  Fill holes with oil and allow to soak in
                                  Easy  safe Storage and identification
                                  #698537
                                  Dave Halford
                                    @davehalford22513
                                    Dipping rubber?
                                    #698564
                                    Andrew Entwistle
                                      @andrewentwistle
                                      For often used cutters I like these trays:
                                      https://www.machine-dro.co.uk/tool-storage-black#mz-expanded-view-1700615589643
                                      Out of stock for singles, but available from machine-dro via eBay 12 for £17
                                      #698567
                                      Emgee
                                        @emgee
                                        Tony English has been selling various sizes of clip together plastic containers for milling cutters recently, the same type that many new cutters are sold in, I had some from him and use them for storage of all types of cutters, they work out low cost storage that can be marked with any permanent marker, I have no connection with Tony other than a satisfied customer on many occasions.
                                        Tony English
                                        Wareham
                                        BH20
                                        UK
                                        01929 473901
                                        #698651
                                        Grizzly bear
                                          @grizzlybear
                                          @ bazyle,
                                          I like your take on the milk container.
                                          You are certainly thinking outside of the  box.
                                          Bear……..
                                          #698705
                                          duncan webster 1
                                            @duncanwebster1
                                            Tony English
                                            Wareham
                                            BH20
                                            UK
                                            01929 473901
                                            I wanted a couple of these but had to bulk buy. If you want a couple pm me and we can come to a deal
                                            #698708
                                            duncan webster 1
                                              @duncanwebster1
                                              Oops, quoted the wrong thread, I meant The MDRO trays
