UCP Bearings for lathe spindle?
Home › Forums › Beginners questions › UCP Bearings for lathe spindle?
Viewing 25 posts - 1 through 25 (of 26 total)
  • #6648
    Ed Duffner
      @edduffner79357
      #116224
      Ed Duffner
        @edduffner79357
        Hi chaps,
        I'm rebuilding a home made lathe and having some difficuties with oilite bearings I've decided to rebuild the headstock and use pillow block bearings. I got hold of some 25mm UCP bearing pillow blocks from Ebay which arrived today and to my mind they seem rather stiff i.e. packed full with grease, but not binding. They are also spherical mounted (self aligning?).
        Can anyone please advise if these will be ok for the main spindle on a lathe. If ok, would they need to be run in?
        Here's a link to the ones I have. **LINK**
        Thank you,
        Ed.
        Edited By Ed Duffner on 06/04/2013 17:58:53
        #116230
        David Jupp
          @davidjupp51506
          Unless otherwise stated I'd expect such bearings to support transvers loads, but not be much good with axial loading – so for a lathe they would support the spindle, but may not cope with much end thrust.
          Also not sure how you would get a precise alignment with the lathe bed, the self aligning nature is to cope with imprecise mounting – not what you want on a lathe.
          #116231
          Sub Mandrel
            @submandrel
            Hi Ed,
            My advice would be to look at either angular contact bearings or taper roller bearings.
            Taper rollers are not the cheapest option, but it would not be unusual only to use one at the front of the headstock witha smaller angualr contact bearing at the back.
            Ed Duffner
              @edduffner79357
              David and Neil,
              Thanks guys, I'll look at those bearings and see what I can fit in there.
              All the best,
              Ed.
              #116243
              Andyf
                @andyf
                "UCP bearing pillow blocks"
                Can't resist pointing out that, when I were a lad and dinosaurs roamed the earth, "UCP" referred to any one of a chain of restaurants, mainly in Lancashire and run by United Cattle Products, which specialised in such delicacies as tripe and cow heels.
                Andy
                #116245
                Sub Mandrel
                  @submandrel
                  "OCP bearing pillow blocks"
                  Where Robocop rests his weary head…
                  neil
                  #116247
                  Ed Duffner
                    @edduffner79357
                    Those new corduroy pillows are making headlines.
                    …sorry embarrassed
                    Edited By Ed Duffner on 06/04/2013 21:53:42
                    Edited By Ed Duffner on 06/04/2013 22:15:09
                    #116249
                      Ed,
                      it would be interesting to see pictures of this home made lathe.
                      I expect you are looking at the pillow blocks because they are self contained with their mounting. Two options come to mind for the thust problem mentioned and both were used in the past on commercial lathes.
                      If there is room to put something behind the back of the spindle and it is not bored through you can put a pointed screw to bear on the rear and take up any slack.
                      Rather better will be to arrange for the spindle to go through a hole in a plate positioned just in front of the rear bearing. Then mount a thust race on that, possibly bearing on the pulley block on the spindle. The initial bearings arrangement will be adequate for the time it takes to use the lathe to make the necessary components because most ball races can take some end force it's just not good for them long term.
                      The fact that they are self aligning makes no difference to your ability to align the spindle with the bed. They may well run more freely when warmed up.
                      #116250
                      Ed Duffner
                        @edduffner79357
                        Hi Bazyle,
                        Thanks for the advice. I've actually just requested a return from the Seller. I'll add add some photos shortly.
                        Ed.
                        #116251
                        Ed Duffner
                          @edduffner79357
                          Before.
                          Lathe 1
                          After strip-down and repaint.
                          Lathe 2
                          Here's one of the spindle and bearings. 1" oilite bearings held in the 0.5" steel plate, but the shaft is 25.3mm so I get a bit of judder when taking moderate cuts.
                          Lathe Spindle
                          Another angle showing a thrust washer and spindle register.
                          Lathe Shaft 2
                          Edited By Ed Duffner on 06/04/2013 23:14:34
                          #116253
                            That was quick.
                            You just need to split the bearings. I suggest you start with just one sawcut along the front bearing and invent a way of tightening it up. A jubilee clip around the bush will close it up but it will then be loose in the frame. So then you need a slit in the frame and a way of closing that up.
                            Lets see what others say.
                            #116254
                            Ed Duffner
                              @edduffner79357
                              Lol, these photos were taken some months back, it's not so shiny now smiley I tried splitting the bearings already and wrapped part of a strap from an electrical earth bonding strap around the full circumference of the bearing like a circular shim and pushed the bearings back in with a clamp, so a very tight fit initially and no play in the bearings, but axial play has reappeared. So I was thinking to chop off the top section of plate on each side and add a flat base with the pillow blocks on.
                              I suppose another possibility is to use new oilite bearings and turn a new shaft to correct size.
                              I do like the idea of adding a clamp into the plate.
                              #116255
                                If the play returned after the split it may indicate that you really need more lubrication. Most plain bearing headstocks have oilers and it doesn't look as if you even have an oil hole.
                                If you are considering going as far as making a new spindle you could make a conical bearing which you might be able to add to the existing one anyway.
                                Is this the Len Mason design?
                                #116256
                                Ady1
                                  @ady1
                                  Getting solid bearings to mate with the headstock housing AND the spindle isn't easy
                                  The bearing has to be drawn around the spindle so it revolves… then the same bearing needs to be locked solidly to the headstock housing
                                  Drummond took a few goes before they sussed it out and it's not an easy adjustment to make
                                  However, there are still many Drummonds still going on their original bearings, including my own
                                  Drummond 31/2" Lathe Headstocks 1902 -1942
                                  #116257
                                  Ady1
                                    @ady1
                                    So if you have already split the bearings they need to be tapered slightly, bigger inside to outside, with a matching taper in the headstock housing
                                    The outside draw nut draws them in and the taper squishes the bearing around the spindle
                                    The bearing split is tapered, wide at the top, narrow at the bottom, and points directly up to the oiler hole
                                    A long bolt goes through the top of the headstock oiler hole and pushes a teeny vertical wedge into the split in the bearing, forcing the outside of the bearing to lock to the headstock
                                    It's fiddly to get things right but Drummonds have a good reputation for stiffness and once it's done it works well for ages
                                    I over tighten the spindle bearings very slightly then the wedge opens things up when the headstock bolt drives it in and locks the bearing to the housing
                                    It may still need tweaking once you get some heat during running
                                    Most lathe producers took the easy cheap route and made pinch bolt headstocks
                                    Edited By Ady1 on 07/04/2013 02:56:50
                                    #116258
                                    Ed Duffner
                                      @edduffner79357
                                      Thank you Bazyle,
                                      To be honest I've no idea as to the design origin. My Dad (also Basil) made it years ago. He was a Fitter at Rolls Royce Filton, Bristol and I was always under the impression it was something he designed and made.
                                      I added the base recently, made from two pieces of 100x100x10 angle welded together and have started converting the leadscrews to metric and delrin half nuts.
                                      #116259
                                      Ed Duffner
                                        @edduffner79357
                                        Thanks Ady,
                                        Looking at the photos in the link you provided, the arrangement seems to be a bronze bearing with tapered OD and parallel ID so that as the threaded ring is tighetened it closes the bearing around the spindle to a sliding or running tolerance. To do it this way I'd have to make a tapered housing to accept a bearing and would the bearings themselves be made of ordinary bronze or some special type?
                                        Ed.
                                        Edited By Ed Duffner on 07/04/2013 03:34:57
                                        #116260
                                        Ady1
                                          @ady1
                                          As far as I know, just ordinary bronze
                                          The Drummond system will give you some ideas
                                          The pinch bolt system for the headstock wouldn't be so dangerous on your headstock because it's 0.5 inch steel
                                          Cast iron is prone to cracking if you tighten headstock pinch bolts up too much, whereas steel is safer for flexing purposes
                                          So a system for squishing the bearing around the spindle
                                          And a pinch bolt for squishing the headstock housing around the bearing
                                          A good headstock pinch bolt may actually do both jobs if the bearing is split and the bearing fits snugly in the headstock housing
                                          This would probbly be your easiest solution
                                          gl
                                          Edited By Ady1 on 07/04/2013 04:02:21
                                          #116261
                                          Ady1
                                            @ady1
                                            The biggest problem for you will be keeping your spindle aligned with your lathe bed once you start messing with the original system and setup, (something well beyond my own limited hacker abilities)
                                            I tend to use the hail mary system when I muck about with old machinery
                                            You will probably drastically reduce the headstock housing stiffness if you change over to a headstock pinch bolt system, the original enclosed headstock housing system he has used looks pretty professional and very solid
                                            It's all a case of compromise and convenience
                                            Edited By Ady1 on 07/04/2013 04:16:16
                                            #116270
                                            Sub Mandrel
                                              @submandrel
                                              Hi Ed,
                                              The lathe looks fundamentally sound, but also constructed in a way that you don't need to feel guilty about maing 'improvements' – it's just ongoing development.
                                              One option that avoids upsetting the accurate holes in the headstock would be to turn up solid bronze bushes to replace the oilite bushes and fit proper oilers. I guess you would probably want to lap these to fit.
                                              Oilite bearings may be long lasting, but they don't hold enough oil to craate the consistent oil fil you need for accurate work.
                                              You could make the bushes on the lathe itself, but do you have access to another lathe?
                                                Posted by Bazyle on 07/04/2013 00:09:23:
                                                No … that was much smaller, and all made from flat stock.
                                                [unless, of course, he designed more than one]
                                                MICHAEL WILLIAMS
                                                  @michaelwilliams41215
                                                  Hi Ed
                                                  (1) Bore out chuck end bearing taper .
                                                  (2) Fit a matching taper sleeve on spindle by shrinking (pref) , pressing or Loctite .
                                                  (3) Fit a designed block outboard at other end of headstock arranged to hold two thin angular contact bearings in a sleeve . Existing bearing at this location is removed .
                                                  (4) Arrange ring nuts to load the two bearings against each other and to adjust end position of pair on spindle for adjustment of running clearance of spindle in chuck end taper . May be nescessary to cut a thread on spindle or provide a shoulder . Various different practical arrangements are possible .
                                                  Regards ,
                                                  Michael Williams .
                                                  #116280
                                                  MICHAEL WILLIAMS
                                                    An easier variation of the same idea uses bearing support blocks fitted outboard at both chuck and other end of headstock each containing an angular contact bearing . Again a ring nut is fitted somewhere to load bearings against each other . One step and one thread on spindle is obvious arrangement but others are possible .
                                                    #116283
                                                    MICHAEL WILLIAMS
                                                      Purely out of interest my late father built a lathe similar to Ed's . Only significant difference was in headstock design . My father used the gearbox casting off a prewar car . All gearing was discarded , new bearings to same spec as old ones were put in and a new shaft made to fit .
