SPARK PLUGS.
SPARK PLUGS.
Home › Forums › Beginners questions › SPARK PLUGS.
  • #113880
    Lloyd Bowers
      @lloydbowers78291
      Hi all, question is sparkplugs. where do you get them or do you make them?
      im doing a specific one off 6cyl engine. and this is mostly my first model. although i do "dabble" and make lots of things. so sorry if some of my questions are simple or strange.
      #6614
      Lloyd Bowers
        @lloydbowers78291
        #113881
          What sizeplugs are you likely to need.
          The CM-6 is common on larger models using an M10x1 thread and readily available from ebay etc.
          For smaller stuff then the Rimfire range start a 10-40 which is approx 3/16 dia thread, then 1/4×32 and can be had from Minimag and Hemmingways.
          Or make your own
          J
          #113883
          Lloyd Bowers
            @lloydbowers78291
            ok im after 3mm if im keeping to scale, but i was looking at converting or making plug from nitro glow pulgs, i think there about 4-6mm.
            how do you make your own, or i should say what material do you use for insulating?
            #113884
            Bob Perkins
              @bobperkins67044
              I'm currently building one of Jan Ridders engines. This includes plans for a spark plug, although I'm using a NGK CM 6. Jan specifies teflon for the insulator, steel for the body and steel wire for the electrode.
              Bob..
              #113885
                Corian is quite good for the insulator. Or let a lump of JB Weld go off and use that.
                I doubt you wil modify a glow plug they are thereaded 1/4x 32 and the hole up the middle is 2.5-3mm
                #113887
                Lloyd Bowers
                  @lloydbowers78291
                  some helpful comments thanks. dont know what way to go, scale version of 3mm is a bit small to work with.
                  #113905
                  Lloyd Bowers
                    @lloydbowers78291
                    OK thanks. I did say if I was keeping to scale I’d be looking at 3mm. But as a novice I didn’t know what sizes are available or used normally. Ill have a bit more of a look and decide. I guess I’m going to be looking at 4-6mm.
                    #113907
                      Rimfire's web site gives sizes of their plugs which should give you something to go by.
                      Edited By JasonB on 06/03/2013 20:17:00
                      #113942
                      Lloyd Bowers
                        @lloydbowers78291
                        Posted by Graham Meek on 07/03/2013 09:27:06:
                        In his series of articles in ME April 1971, L. C. Mason says he sucessfully made some 4 BA spark plugs for his 4 Cylinder 4 cc 4 stroke engine, there is also a drawing for a 5/32 x 40 TPI spark plug with an Araldite insulator, these should be available digitally I would imagine.
                        Gray,
                        that would be good. ill have to start googling!!! cheers
                        #113980
                        Ian S C
                          @iansc
                          There have been a number of articals in ME about making spark plugs, One used machinable ceramic, another, might be similar to Grey's teflon one, araldite I think was mentioned. An interesting one consisted of a metal body with a bit of glass tube melted into it, the tube came from inside an incandesant light bulb, the exposed insulator on top was a little ceramic insulator that you sometimes find on heating element lead in wires. Ian S C
