Hit and miss engines.
Home › Forums › Beginners questions › Hit and miss engines.
  • #5195
    Frank Dolman
      @frankdolman72357
      #55977
      Frank Dolman
        @frankdolman72357
             Why, please, are Hit and miss engines so called?
        #55979
        John Olsen
          @johnolsen79199
          Because the usual form of governor for these engines works by holding the exhaust valve open when the engine reaches the desired maximum speed.  This causes the engine to stop firing, then as it slows down the exhaust valve is released again and the engine starts firing again. This gives a characteristic sort of chuff..chuff..chuff..clickey clickety chuff chuff chuff beat to the engine. When you put a load on, they fire more often and at maximum load will never quite reach the maximum speed so they don’t miss any beats.
          regards
          Frank Dolman
            @frankdolman72357
               Thank you John.  Very clear.
            #56005
            John Wood1
              @johnwood1
              Hi.  When if fires it ‘hits’ and when the open exhaust valve prevents this it ‘misses’ Have a look on YouTube and you will find several videos. Fascinating engines to watch!
              Cheers
