Hobbymat Lathe
Hobbymat Lathe
Home › Forums › Beginners questions › Hobbymat Lathe
  • #4755
    DAVID HOWORTH
      @davidhoworth40264
      Spares / new parts
      #43335
      DAVID HOWORTH
        @davidhoworth40264
        Dear Members,
        I would appreciate any advice as to where I can obtain any new and spare parts for the Hobbymat MD65 Lathe.
        Also is there any connection between the Hobbymat and Unitech lathes.
        #43339
          Yes there is a connection you can see from the first sentence
          E-bays a good as place as any to look, also Homeworkshop
          Jason
          #43341
          Timothy Williams
            @timothywilliams35501
            SL Supplies  – [email protected]
            was supplying spares for MD65 about one year ago.  He said there was a newer version
            SD300 which  might be downwardly compatible.
            Tim Williams
            #43343
            DAVID HOWORTH
              @davidhoworth40264
              Posted by Timothy Williams on 05/09/2009 21:59:57:
              Tim Williams
               Thanks Tim, I am aware of the company and am already in contact with him for various bits and pieces.
              I was just wondering if there were any others  I could have contacted so as to compare prices etc. as I have always been advised to do so if possible.
              Kind regards,
              David Howorth.
              #43344
              DAVID HOWORTH
                @davidhoworth40264
                Posted by JasonB on 05/09/2009 20:54:49:
                Jason
                Thank you for the reply Jason, and for the conformation that there is a connection between the two lathes.
                The Homeworkshop link you suplied looks like it could be useful in the future.
                Best regards,
                David.
                #43871
                Graham Horne
                  @grahamhorne65034
                  David, you are lucky, I posted a similar question about MD65 some months ago and was ignored! Was it my breath? I will ride along on your site if you don’t mind. Graham
                  #43873
                  DAVID HOWORTH
                    @davidhoworth40264
                    Posted by Graham Horne on 28/09/2009 23:22:32:
                     Hi Graham,
                    No problems, I must have been lucky in getting a couple of Members who chose to give my request some thought, and reply, though I myself expected more Members to respond,as obviously you did.
                    I hope that the replies given by Tim and Jason were of some help to you as they were to me, as I have ordered some components from Stephen Lacey a few days ago, and expect delivery in a couple of weeks or so.
                    Regards, David.
                    #43925
                    Paul tindall
                      @paultindall15814
                      Hi,
                       as a second hand MD65 owner too, I’d be glad to share experiences with anyone on this site. I’m a beginner, but have adapted a chinese 4 jaw and am looking into adapting a fixed steady as well.
                      I’ve not needed any spars yet but   have contacxted – stephenlacey who seems to be the man. I probably need a metal 20T gear soon as my plastic one is getting a bit worn/mangled.
                      Its a quality machine. Not sure how it would compare to a Sieg C1/C3, but it does most of what I want it for. Could do with a mill or milling attachment  for it, but that’s for later when funds permit.
                      Paul
                      #43934
                      DAVID HOWORTH
                        @davidhoworth40264
                        Hello Paul,
                        It would obviously be very useful to keep in touch on this Forum to swap details of what MD65 users are up to with their experiences etc. of using the machine.
                        I looked at buying the mill attachment but have decided against it and gone for a seperate vertical milling machine so as not to interfere with turning operations.
                        Stephen Lacey does know an awful lot about the MD65 lathe, and is always willing to talk about them and accessories available for them.
                        David.
                        #44730
                        Neil Tucker
                          @neiltucker48479
                          Hi Chaps,
                          Just bought mine today for an absolute song, trouble is, it needs some bits and pieces (screw cutting gears, tailstock chuck, Chuck keys) but looks like it has been unused and has sat in a garage until the last owner sadly past away. Very little use.
                          I take it that a lot of stuff is standard sizing (tailstock chuck for example), but for the screwcuting gears (and indeed the knob that engages the drive!) I have a feeling I will need to speak to Stephen Lacey.
                          Is there a number anywhere for him?
                          Jeez, can a man be so happy as a man with his first lathe? Even if it isn’t an ML7 and might need a little cleaning…right, where are those plans for a 1/4 scale merlin
                          Tally Ho!
