Drone advice needed, please
Home Forums Related Hobbies including Vehicle Restoration Drone advice needed, please
Viewing 25 posts - 1 through 25 (of 26 total)
  • #34519
        I was considering paying for a ‘Drone Survey’ of a site, to supplement my conventional measurement … But a quick cost/benefit analysis suggests that buying a small drone would be a much better idea !!
        Steve’s recent thread: **LINK**
        https://www.model-engineer.co.uk/forums/postings.asp?th=179395
        suggests that a 249g drone would suffice surprise
        Obviously, I would like something with the optics to do photogrammetry … but let’s keep this realistic …
        Can anyone please point me to representative imagery from a low-flying, modestly priced, easily handled drone ?
        I only need static nadir images from a few specific locations, and video of a general fly-around.
        Grateful for any advice.
        Juddy
          @juddy
          There is now Regulations for where and who can fly drones which also require registration and training how much training I think depends on the size of the drone and what your going to do with it. I don’t think its complicated but it does need consideration before going out and spending money.
          Register to fly a drone or model aircraft | Civil Aviation Authority (caa.co.uk)
          #598097
          Howi
            @howi
            the test is easy, have the rules and regs open while you do the test paper.
            After you pass you will have to pay £10 to the Gov. you will get an OPERATOR ID and a FLYER ID, Flyer ID is foir you the flyer of the drone, the OP id is for the owner of the drone. The OP id is in the form GBR-OP-############ and should be displayed on the drone. Drones under 250grams are subject to less restictions than larger drones and can be flown just about anywhere ( subject to official no fly zones such as airports, prisons etc.
            Another important must have is INSURANCE, what damage can a sub 250gram drone do?
            Try telling that to the judge when you are being sued for taking someones eye out……..
            Basically the rules and regs have almost put paid to larger drones apart from commercial use.
            the biggest impact has been on model aircraft flyers who are now subject to the same rules and regs..
            ALL model aircraft are classed as drones.
            they are good fun though……..
            #598099
            Joseph Noci 1
              @josephnoci1
              Posted by Michael Gilligan on 13/05/2022 08:59:03:
              How will you process the 'few' images Michael? I build drones ( fixed wing) that Surveyors use for land survey – fitted with reasonable ( 25mpxel) cameras and 50mm lenses – we fly with autopilot, a ladder track over the area taking photos that have left/right/forward overlap of 40 to 60%. We used Agisoft software to process – creating full 3D imagery, full dimensions, volumes, etc. Used a lot by local mines to determine stockpile volumes versus mined 'hole' volume, etc. Camera sensor size/pixels, lens focal length, etc all play a role in ground resolution – so not sure what you are after – We have obtained very good results – 10cm ground accuracy to 2sigma – with simple cameras Canon Powershot – pocket camera – 350grams, with a pentax fixed focus 50mm lense. FLight height above ground should be better controlled if sub 10cm ground resolution is needed…since I don't know what you need, I cannot comment!
              #598110
              Speedy Builder5
                @speedybuilder5
                What constitutes to be an aircraft? Are there minimum weights, size etc.
                Eg: Is a paper dart an aircraft ? A chuck glider, again a 20p chuck glider sold on the beach as opposed to a competition glider which could be seriously large and heavy.
                #598115
                Old School
                  @oldschool
                  Anything over 250g requires registration. But some regulation applies to those less than 250g you need to wade through the regs.
                  #598118
                  bernard towers
                    @bernardtowers37738
                    plus you need a licence to take photos with it!
                    #598129
                      My toy drone is under 250g and takes photos but it's quite hard to fly: a few hours wasn't enough for me to reliably steer it around a course, even with no wind. Even after much practice I'm nowhere near good enough to aim the camera accurately. Transmitter range, fly time, and height are all limited. Might be good enough if Michael's needs are trivial, but the amount of effort needed to learn to fly it is off-putting.
                      A friend has a £600 drone which he says is easy to fly and great fun. Three or four times bigger than mine. No problem getting up to 400 feet, it's auto-stabilised, obeys orders smoothly,the transmitter range is several hundred meters, and if the control signal is lost, the drone flies itself back to the launch point and lands. It has GPS and knows where it is to within about 5 metres. He can also see what the camera is looking at. This would do the job I think, apart from processing the images. However I wouldn't spend £600 on a drone that only did a few jobs, I'd need more fun out of it. Worth checking drone prices though – they've been coming down steadily over the last few years. What my friend wanted was about £2000 when he first enquired 5 or 6 years ago. He waited!
                      duncan webster 1
                        @duncanwebster1
                        Helium balloon (perhaps several), a long string and a camera with radio control shutter
                        #598137
                          Kite aerial photography…?
                          I recall a magazine publishing an article on the subject some little time ago.
                          #598138
                            Posted by bernard towers on 13/05/2022 12:52:23:
                            Only for commercial purposes.
                            #598145
                            Steviegtr
                              @steviegtr
                              Hi Michael. The Drone used in my Holiday vids was a DJI Mini 2. Under 250 grams. 4K 30 video. The controller is like a playstation controller. It takes your smart phone at the top & that is your viewing area.
                              You can switch midflight between photo or video. It has 2 times zoom. The Gimble on them is rocksteady. The video i posted was in Fuerteventura & it's always very windy there. Over 20mph but the Drone copes well with winds up to 22mph.
                              It is very easy to fly after a few tries at your local field. As usual i bought mine 2nd hand & has been great.
                              Not the cheapest Drone but very good. The Mini3 has just come onto the market & is even better with 4K 60, & has a 1/1.3" x 1.7 lens.
                              The other good thing about the DJI is the batteries are smart. Lithium polymer. If you have them fully charged & don't use the Drone for a whil the batteries automatically drop to 90%. After a few weeks of not using they drop further to i think 60%. So the batteries will have a long life.
                              I took the simple test online without much knowledge & passed. So i do have my flyer id & drone i.d. But it is not actually needed for under 250Grams weight. With those you can fly over buildings / over people . But not over crowds. The app tells you when it is safe to fly I.E how many Satellites it's picked up & return to home has been set. Any flight paths where you should not fly. It even brings up a Google map on the screen. You can toggle between the camera & the map to see where you are.
                              In Conclusion they are an amazing little Drone , as i am sure some others are too. I think Autel do a nice one.
                              It turned into a bit of a Hobby for me & so far no regrets buying it. They must be the ultimate tool for surveying building walls , brickwork, windows & roofs. Or even area's. Flight time is around half an hr per battery. Height unlimited but regs say 400 ft max. Distance . Some guys on you tube fly them up to around 4 miles & back. Not legally though.
                              Hope this is of some help.
                              Steve.
                              #598146
                              HOWARDT
                                @howardt
                                As an alternative have a look at Promap.co.uk. A friend used there location mapping services when he worked creating updated building service plans. They can supply location maps and many other types of ariel views for a price, nothing to loose looking at the web site.
                                #598163
                                  Posted by Juddy on 13/05/2022 10:00:26:
                                  There is now Regulations for where and who can fly drones which also require registration and training how much training I think depends on the size of the drone and what your going to do with it. […]
                                  yes
                                  That’s one of the reasons I was interested in the 249g one that Steve mentioned.
                                    Posted by Neil Wyatt on 13/05/2022 15:22:34:
                                    Not really convenient … I specifically want nadir images from identifiable locations and [say] 10m altitude.
                                    MichaelG
                                    #598167
                                      Posted by SillyOldDuffer on 13/05/2022 13:50:34:
                                      A friend has a £600 drone which he says is easy to fly […]
                                      Which might make the £250 that I have been quoted for a ‘Drone Survey’ more reasonable than I thought
                                      … more research required
                                        O.K. … for clarity here are some numbers for the immediate need
                                        The site is a thin quadrilateral, approximately 476 square metres, with a perimeter of about 109 metres
                                        [ values derived from Google Earth ]
                                        … I am guessing that a flight altitude of 10m would be reasonable, but am open to advice from the wise.
                                        Google Earth satellite images don’t have enough resolution, but the Street-View quality would probably suffice.
                                        I will be doing a traditional survey, but want drone images to supplement it.
                                        Anonymous
                                          Lot's of rules and regulations – even after Brexit – but what actually happens in real cases such as Michael's? A small piece of private land that needs quickly surveying from 10 metres height. End of.
                                          Do people just go ahead anyway and feign ignorance?
                                          #598180
                                            Something approaching the quality of the ‘Roof Surveys’ on this page would be fine:
                                            Drone Roof Survey Footage
                                            Steviegtr
                                              @steviegtr
                                              10mtrs is fine. As long as nothing around is higher. Easy to fly back or sideways to hit if so.
                                              I survey the area & set a height above the highest point.
                                              With 4k you will get stunning clear shots & photo,s.
                                              The ones I did on hol over the sea are very clear at around that height.
                                              Steve.
                                              #598185
                                                Posted by Peter Greene 🇨🇦 on 13/05/2022 18:35:38:
                                                More rules and regulations after Brexit, not fewer!
                                                The Drone rules were introduced after Gatwick and Heathrow airports had to be closed due an mixture of terrorist threats, political demonstrations, and stupid copycats. The rules are lightweight and no-one cares about policing drones unless the flight is a risk to the public. Previously it wasn't illegal to close the world's busiest airport by flying a drone over it, now it is!
                                                  Posted by Steviegtr on 13/05/2022 19:08:55:
                                                  Steve.
                                                  That’s very encouraging, Steve … Thanks
                                                  Anonymous
                                                    Posted by SillyOldDuffer on 13/05/2022 19:52:22:
                                                    It wasn't already covered under existing rules for model aircraft or was that too specific? Leads one to speculate that they have a set of rules each for model aircraft, model helicopters, drones … all saying the same thing. Instead of drafting a single, "no flying object" law which would also cover such things as flying i-Phones when they come along.
                                                    (Such comprehensive rules would have to make some exceptions of course, particularly the obvious two).
                                                    #598196
                                                    pgk pgk
                                                      @pgkpgk17461
                                                      Is there a local r/c flying club? I haven't flown my helis in a long time -most have only 5/6mins time per battery pack but as example my petrol "gasser" is good for 20+.mins aerobatic or 40mins with the original lower performance engine and quick to refuel.
