Milling cutter
Milling cutter
  • #33752
    john fletcher 1
      @johnfletcher1
      #515553
      john fletcher 1
        @johnfletcher1
        My mill is R8 and I have been giver a cutter and on the stem part of the R8 some one has engraved TCMT 2 (1.5 ) 7-UM 4025 P25 K 20. The cutter has two damaged triangular cutter. I have been looking to buy replacement but can't find any thing with those details. Will some one please point me in the right direction. Not urgent and will the cost give me heart problems. John
        Happy new year to all..
        #515559
        DC31k
          @dc31k
          The insert designation is using the ANSI (American) system. Inserts sold here use the ISO system.
          There is a very useful chart here that has both languages on it:
          http://www.carbidedepot.com/formulas-insert-d.htm
          With inserts, the importance of the information conveyed decreases considerably the further to the right that you read. Some of what is shown on your cutter is likely a manufacturer-specific grade of carbide.
          For buying replacements, start at the left and get the basic shape. Then, for your chosen manufacturer, look at their literature and choose one of their offerings to suit the material being cut.
          #515577
          old mart
            @oldmart
            TCMT 110204 is the size, you can check the diameter of yours. Just imagine a circle fitting within the triangle, if it is 11mm then the size is right. The thickness is 2.38mm. TCMT 110304 is 3.18mm thick. Lots on ebay. P25 is a common grade for steel.
            Edited By old mart on 26/12/2020 18:03:22
            Edited By old mart on 26/12/2020 18:06:59
            #515589
            Chris Evans 6
              @chrisevans6
              I may have some TPUN inserts that would possibly fit, they are a turning tip but a quick touch on a diamond wheel and they work well for milling. I will look tomorrow and if I have any I will let you know and post for the cost of posting.
              #515595
              Dave Halford
                @davehalford22513
                This guy sells older style carbide off cheaper than most.
                #515597
                DC31k
                  @dc31k
                  Posted by Chris Evans 6 on 26/12/2020 20:35:01:
                  When you post them to him, how will you send him the hole in the middle of the insert, that he needs for securing it? The second 'T' in his TCMT is quite important…
                  #515621
                  Chris Evans 6
                    @chrisevans6
                    Posted by DC31k on 26/12/2020 21:11:12:
                    I was just looking at the insert size, I did not know the code refered to a hole. Guess I can't help but will still look in my box of unused inserts in case I have something suitable.
                    #515634
                    Martin W
                      @martinw
                      John.
                      Message sent re inserts.
                      Martin
                      #515645
                      john fletcher 1
                        @johnfletcher1
                        Many thank to all who responded to my request for information/help. The tool has just two triangular shaped tips with a recessed hole for the security screw. The existing tip is 2.5mm thick, the sweep is 25mm and from the base to the apex of the triangle it is 8.68mm What I don't want to do is buy some tips which I am unable to use. Having looked on the net there is just so much information of which I don't understand. John
                        #515660
                        Steviegtr
                          @steviegtr
                          Posted by john fletcher 1 on 27/12/2020 12:04:42:
                          John why not try to post a picture of the inserts with a ruler beside it. It may give members a better idea.
                          Steve.
                          #515694
                          old mart
                            @oldmart
                            https://www.iscar.com/eCatalog/Item.aspx?cat=5504887&fnum=530&mapp=IS&GFSTYP=M&srch=1My inscribed circle in the third post was wrong, yours should be about 1/4" (6.35mm) diameter. The sides should measure just over 11mm. These TCMT 110204 are common.
                            Edited By old mart on 27/12/2020 15:09:51
