What core cable.
What core cable.
Home › Forums › Electronics in the Workshop › What core cable.
  • #612106
    Haydn Callow
      @haydncallow19480
      Me again with another beginners question :- I have just got myself a Gryphon 0.25 hp motor. I want to keep it as a spare for my ML7 lathe.
      it has come after having had new bearings fitted and runs very quiet and smooth.
      it also came with a 3 core cable and plug and runs in one direction only.
      I would like to rewire it so I can select Fwd/Rev using a drum switch.
      I have a drum switch with 2 rows of 4 contacts.
      the motor has 4 terminals. Z1. Z2. A1. A2
      A1 seems to be connected to Z1 via a copper link
      A2 seems to be connected to Z2 via a copper link
      how ‘very simply please’ do I connect the Mains, Drum switch and motor together to achieve what I want and how many cores does the cable need from motor to switch, and if possible how thick do the cores need to be ? I.e. .75mm,1mm, 1.5mm
      long question but I am learning and you have sorted my previous 2 ??s very quickly
      thanks
      #32280
      Haydn Callow
        @haydncallow19480
        #612107
        John Haine
          @johnhaine32865
          That's possibly a bit small for a ML7, however…
          Does it have an obvious capacitor? If it does then it should be reversible in the way you want.
          As for using it as a spare, induction motors almost never give up unless either the bearings wear out or the start/run capacitor(s) give up, usually the latter. So your main motor is very likely to be easily repairable if it does go.
          #612108
          Haydn Callow
            @haydncallow19480
            Thanks,
            yes it does have a capacitor…. The motor is I understand original to a ML7. The motor on my lathe was new a month ago and gave up….it would only go in reverse…..see my previous topic…the manufacturer is replacing it for me.
            #612109
            John Haine
              @johnhaine32865
              Well without knowing exactly how the cap is connected I'm not sure how you reverse it, but I would guess that one winding must be Z1-Z2 and the other A1-A2, and one of these has the cap in series. At the moment it's connected Z1-A1 and Z2-A2, I would guess that if you connect Z1-A2 and Z2-A1 it would run in reverse as you have reversed one winding's sense relative to the other. As for the number of cores, there are only 4 terminals (plus earth presumably) so it can't be more than 4! As for size the same size as on your main motor. Wiring these funny switches I have no knowledge of I'm afraid.
              #612110
              peak4
                @peak4
                Here you go, not only will this site show you how to refurbish a Dewhurst switch, it will also show how to wire one.
                https://misterlinnsworkshop.wordpress.com/2014/03/08/dewhursts-big-switch/
                Re. the number of cores in the cable, I'd go for 5 core, as you need 4 plus an earth.
                You could use 4 core and earth separately, but if you need to buy some cable anyway………………
                Bill
                Edited By peak4 on 02/09/2022 16:14:10
                #612111
                Haydn Callow
                  @haydncallow19480
                  The capacitor is connected to Z1 & Z2. Red wires
                  the windings to A1 & A2 Black wires
                  #612113
                  Haydn Callow
                    @haydncallow19480
                    Peak4….great, thanks…..
                    Edited By Haydn Callow on 02/09/2022 16:22:10
                    #612116
                    noel shelley
                      @noelshelley55608
                      A .25Hp motor will only do small work on an ML7 ! Should be 0.5Hp Start windings should be blue and Yellow, run windings should be red and black. It sounds like a dewhurst drum switch. A1 and A2 run and Z1 and Z2 start ' 1,2,3,4, on left 5.6.7.8. on right of switch.. Live to No1 Neutral to No3 earth to the earth stud or bear metal point VITAL ! A1 to No5, A2 to No 7, Z1 to No6 and Z2 to No2. IF the direction is wrong on the switch swap No6 and No2.. ONLY use this switch to change direction of rotation, stop and start with a seperate switch. NEVER change direction whils the motor is still turning ! . Good luck Noel.
                      Edited By noel shelley on 02/09/2022 17:33:23
                      #612119
                      Haydn Callow
                        @haydncallow19480
                        Thanks for that….it’s not a Dewhurst but very similar…..made in China , green oblong….plenty to see on eBay….dammed if I can work out how to post a picture on here. I’m on a iPad
                        #612120
                        noel shelley
                          @noelshelley55608
                          To answer your question 5 core 1.5 mmsq Noel..
                          #612123
                            Posted by noel shelley on 02/09/2022 17:38:58:
                            I would think 1mm ^2 or even less,is likely sufficient. It’s not much bigger than a good sized soldering iron!🙂
                            #612151
                              I'd think twice before fitting a motor that small – it will limit how fast you can work, and the motor will often be pushed to the max. Half to one horse-power is more usual, and a boy racer might go bigger still…
                              #613780
                              Haydn Callow
                                @haydncallow19480
                                All good and working well, thanks everyone
                                #613800
                                  Hope you are not using the drum switch as the main on/off. That will burn the contacts – you need to get a 'no volt release' unit. Probably got that in the Myford wiring but in case you decided to use this motor on some other little project.
