pipe + nipples
pipe + nipples
Home Forums General Questions pipe + nipples
  • #531392
    Garry Coles
      @garrycoles69390
      Hi. I was wondering whether to solder or silver solder 5/32 copper pipe to the nipples. My working steam pressure is 90 PSI and I would have thought soft soldering would be strong enough. Can some one advise me please.
      Garry
      #28021
      Garry Coles
        @garrycoles69390
        #531400
        Philip Rowe
          @philiprowe13116
          Silver solder every time. Whenever in the past I have soft soldered nipples I have always regretted it as they inevitably fracture/break. Phil
          #531652
          Keith Hale
            @keithhale68713
            Hi Gary,
            Aim for a joint gap of about 0.1mm radial.
            Aim for a joint length of 5-6x wall thickness of the tube.
            Ensure components are free of grease. Use appropriate flux.
            Ideally position soft solder (ring?) Inside the nipple. Like a Yorkshire fitting
            Heat the nipple to draw the solder through the joint.
            90 psi? a walk in the park.
            Expect a joint strength 100 x that
            Keith
            #531670
            MichaelR
              @michaelr
              I agree with Phil, I always silver solder pipe and nipples and never had bother with fractured joints.
              If your pipe work is for your William Loco or that D&NY you show in your album then your pipe work needs to be silver soldered.
              Michael.
              Edited By MichaelR on 04/03/2021 15:31:25
