The recent thread on compressor selection got me wondering if a car air conditioning pump could be made into a useful quiet compressor.
Plenty of folk, me included, have built reciprocating compressors around redundant industrial refrigeration pumps or lorry brake air pumps. Mine worked well but, being reciprocating, were noisy. Basic A/C pumps are rotary sliding vane types so should be quiet.
Finding proper data on actual pump performance is beyond my Google-Fu but it seems typical displacement is around 100 – 120 cc and input output pressure range around 45 to 150-175 psi. Power consumption is said to be around 3 hp / 4 kw.
Plugging the numbers into a very handwaving analysis the 3 hp power consumption suggests something around 8 cfm at over 100 psi could be available when run at 6,000 rpm. Drop it down to 1,000 rpm it could be driven by 1/2 hp gives perhaps 1.5 cfm. Plenty for running a model or spraymist / fog buster type cutting oil supply although 1 cfm at 600 rpm from 1/3 rd hp drive should be more than enough for cutting oil supply.
Silding vanes need lubrication so there would have to be some sort of drip feed lubrication on the input side, air tool feed bottle I guess, and your application would need to be tolerant of a little oil in the air supply. Can't see an issue with models or spraymist / fog buster.
Modern sophisticated ones are swashplate pumps which probably wouldn't do well unless more oil than desirable were used.
Dunno how well the economics stack up. £30-£40 from a breaker for a pump then there is the motor and all the other bits. Possibly something north of £100 – £150 if you have to buy everything. But it you just happen to be standing in the way of a cheapy with a dead pump on its way to the skip ….
