Where to buy a new CE stamp?
Home › Forums › General Questions › Where to buy a new CE stamp?
  • #347317
    nigel jones 5
      @nigeljones5
      My old stamp is broken, place I bought it from no longer exists so I need a new one – any suggestions as I cant find an off the shelf one on internet?
      #25899
      nigel jones 5
        @nigeljones5
        #347319
        MichaelR
          @michaelr
          Is this any help **LINK** Mike.
          #347336
          nigel jones 5
            @nigeljones5
            Thanks Michael – thats exactly what Ive been looking for
            #347337
            nigel jones 5
              @nigeljones5
              ahhhh…mine has top be 50mm minimum and their biggest is 10mm…I will give them a call!
              #347387
              Chris Gunn
                @chrisgunn36534
                Fizzy, why not get some name plates blanks with the CE mark laser cut in and stamp all the other info on before fitting. No need for a big punch then.
                Chris Gunn
                #347389
                  Posted by fizzy on 24/03/2018 11:23:43:
                  Why do you need 50mm high characters for your little boilers? I would have thought 5mm would be quite adequate
                  #347394
                  KWIL
                    @kwil
                    Chris,
                    I would have thought that sticking a nameplate on would not be accepted as permanently marked.
                    #347395
                      I've seen the plates tack welded to steel boilers, John Rex ones spring to mind.
                      Also seems good enough for Tornado
                      Edited By JasonB on 24/03/2018 17:16:18
                      #347396
                        "the CE marking is at least 5 millimetres – unless a larger minimum dimension is specified in the relevant directive."
                        #347397
                        blowlamp
                          @blowlamp
                          I could have a go at CNC milling a punch for you, if you get stuck.
                          Martin.
                          Edited By blowlamp on 24/03/2018 17:31:18
                          #347404
                          duncan webster 1
                            @duncanwebster1
                            You must use a damn big hammer to make a mark with a 50mm punch
                            #347442
                            Meunier
                              @meunier
                              Posted by duncan webster on 24/03/2018 17:55:58:
                              No hammers Duncan. it's all down to "witchcraft" I believe.
                              DaveD
                              #347443
                              Chris Gunn
                                @chrisgunn36534
                                KWIL, my 4CD boiler has a plate just like I describe tack welded to the boiler. Most machinery has nameplates stuck on or screwed on, I have never seen anything with stamped CE marks, but then again I have never bought one of Fizzy's boilers.
                                #347444
                                  I knew I had seen a good photo on a model boiler, ones from AJB below. Bit bigger than Fizzy usually knocks out, these are 13" dia
                                  Edited By JasonB on 24/03/2018 20:59:09
                                  Edited By JasonB on 24/03/2018 21:01:43
                                  #347462
                                  nigel jones 5
                                    @nigeljones5
                                    thank yolu all – i made a reading error. 5mm is the minimum, but the cheapest is still £50, thanks one and all
                                    #347696
                                      Posted by fizzy on 24/03/2018 23:39:50:
                                      Photo Etching?
                                      #347704
                                      peak4
                                        @peak4
                                        There's a few more firms in Sheffield who make stamps Mick Shaw at Portland works for one, or maybe Davidsons
                                        Bill
                                        Edited By peak4 on 26/03/2018 23:08:49
