The world of model and hobby engineering
Forums
Help
Register
Log in
Home › Forums › General Questions › Where to buy a new CE stamp?
My old stamp is broken, place I bought it from no longer exists so I need a new one – any suggestions as I cant find an off the shelf one on internet?
Is this any help **LINK** Mike.
Thanks Michael – thats exactly what Ive been looking for
ahhhh…mine has top be 50mm minimum and their biggest is 10mm…I will give them a call!
Fizzy, why not get some name plates blanks with the CE mark laser cut in and stamp all the other info on before fitting. No need for a big punch then.
Chris Gunn
Why do you need 50mm high characters for your little boilers? I would have thought 5mm would be quite adequate
Chris,
I would have thought that sticking a nameplate on would not be accepted as permanently marked.
I've seen the plates tack welded to steel boilers, John Rex ones spring to mind.
Also seems good enough for Tornado
Edited By JasonB on 24/03/2018 17:16:18
"the CE marking is at least 5 millimetres – unless a larger minimum dimension is specified in the relevant directive."
I could have a go at CNC milling a punch for you, if you get stuck.
Martin.
Edited By blowlamp on 24/03/2018 17:31:18
You must use a damn big hammer to make a mark with a 50mm punch
No hammers Duncan. it's all down to "witchcraft" I believe. DaveD
KWIL, my 4CD boiler has a plate just like I describe tack welded to the boiler. Most machinery has nameplates stuck on or screwed on, I have never seen anything with stamped CE marks, but then again I have never bought one of Fizzy's boilers.
I knew I had seen a good photo on a model boiler, ones from AJB below. Bit bigger than Fizzy usually knocks out, these are 13" dia
Edited By JasonB on 24/03/2018 20:59:09
Edited By JasonB on 24/03/2018 21:01:43
thank yolu all – i made a reading error. 5mm is the minimum, but the cheapest is still £50, thanks one and all
Photo Etching?
There's a few more firms in Sheffield who make stamps Mick Shaw at Portland works for one, or maybe Davidsons
Bill
Edited By peak4 on 26/03/2018 23:08:49
Started by: Andrew Tinsley in: Model Engineer.
Started by: Niels Abildgaard in: Manual machine tools
Niels Abildgaard
Started by: Bob Sillitoe in: General Questions
Bob Sillitoe
Started by: teamricky in: Stationary engines
teamricky
Started by: elowen01 in: General Questions
Neville Chase
Started by: Nigel Graham 2 in: Manual machine tools
Vic
Started by: William Harvey 1 in: Help and Assistance! (Offered or Wanted)
duncan webster 1
Started by: Kiwi Bloke in: General Questions
elowen01
Started by: cedricvale in: Introduce Yourself – New members start here!
Brian Baker 2
Started by: Peter Venn in: General Questions
Speedy Builder5
Started by: Ronald Wagner in: Model Engineer & Workshop
Started by: Garry Coles in: General Questions
Nigel Graham 2
Started by: Speedy Builder5 in: Materials
Started by: blowlamp in: CAD – Technical drawing & design
blowlamp
Started by: Graham Meek in: Manual machine tools
Graham Meek
Started by: lctikka61 in: Manual machine tools
John Haine
Started by: Rainbows in: Workshop Tools and Tooling
Rainbows
Started by: Jens Eirik Skogstad 1 in: Electronics in the Workshop
Huub
Started by: Speedy Builder5 in: Workshop Tools and Tooling
Dave Wootton
Started by: Speedy Builder5 in: Electronics in the Workshop
Started by: Ger in: Manual machine tools
Ger
Started by: Dalboy in: The Tea Room
not done it yet
Started by: JasonB in: The Tea Room
Dave S
Started by: Pixel_Porpoise in: Help and Assistance! (Offered or Wanted)
Paul Lousick
Started by: davelong22 in: Beginners questions
old mart
