Heavy metal
Heavy metal
Home › Forums › General Questions › Heavy metal
  • #25451
    Cornish Jack
      @cornishjack
      #312672
      Cornish Jack
        @cornishjack
        G'dy all.
        I'm sure there has recently been a thread dealing with heavy metals but I can't find it. Heavily into workshop tidying/clearing and found, in my toolbox, a 2.25" x 5/8"(That's fradections!!cheeky) round bar. It is VERY heavy and (from memory) was purchased some 30 years ago to provide crankshaft balance for a home-built Matador 60 – (never completed, of course!!) The few remaining brain cells say that this was depleted uranium (dull, dark grey colour?). Any clues as to how to identify it, please?
        rgds
        Bill
        #312678
        duncan webster 1
          @duncanwebster1
          measure it's specific gravity by weighing it in air then submerged in water. The difference gives you the weight of water displaced, and 1 kg of water weighs 1 kg, so you can work out the volume. Divide the weight in air by the volume and hey presto.
          If you suspect it is uranium, don't be tempted to cut it, it is an alpha emitter and a heavy metal poison, so inhaling the dust would not be a good idea. Uranium is 18.9 kg/litre, tungsten is 19.6. The difference is enough if you're careful with your measurements. Freshly machined Uranium is silvery white, but it oxidises fairly quickly to a dull dark grey colour. Search wikipedia for a photo.
          Just hope it isn't Uranium as getting rid of it safely and legally will probably be a nightmare
          #312682
          Henry Artist
            @henryartist43508
            A Geiger counter might be useful…
            They're not cheap to buy though quartz fiber dosimeters can be obtained for a reasonable sum.
            If it turns out to be a ferrous metal you could do a Spark Test. Section 7.4 of "The Model Engineer's Handbook" by Tubal Cain has the details for this.
            The next test would be to determine the specific weight and density of the material. For this you need to know the weight (easy enough to determine) and the volume it occupies. To calculate the volume either measure it or immerse it in a liquid and see what volume it displaces. Then it's just a matter of looking up the density of the material you have.
            If it happens to burst into flames when immersed in water then there's a good chance it was a bar of sodium… wink
            #312685
              Uraniium? Yikes.
              Seems like it's more common to use either tungsten or Mallory metal for crank balancing. Are you sure it's not one of those?
              #312709
              Swarf, Mostly!
                @swarfmostly
                There used to be an alloy called 'GEC Heavy Metal' (made by guess who?!) that was intended to be used for counter-weights to balance aircraft flight surfaces (elevators, ailerons & rudders). Dense was good as the counter-weights balanced at a shorter radius giving a smaller swept volume and so not needing as much space within the non-moving parts of the airframe.
                I've no idea of its constitution. Perhaps Andrew knows?
                Best regards,
                Swarf, Mostly!
                #312711
                Geoff Theasby
                  @geofftheasby
                  Depleted uranium WAS used, but now Tungsten, I believe.
                  Geoff
                  #312712
                  Geoff Theasby
                    @geofftheasby
                    From PPPrune –
                    "RUDDER/ELEVATOR BALANCE WEIGHT – REMOVAL/INSTALLATION
                    1. General
                    A. This procedure includes removal and installation of balance weights for
                    the rudder and elevator while control surface is still installed on the
                    airplane. Balance weights can be made of tungsten or depleted uranium.
                    WARNING: THE RUDDER AND ELEVATOR MUST BE PROPERLY BALANCED AT ALL TIMES.
                    AN OUTBOARD ELEVATOR OR RUDDER THAT DOES NOT MEET THE
                    REQUIREMENTS SPECIFIED IN 51-80-02 OR 51-80-03 OF THE
                    STRUCTURAL REPAIR MANUAL CAN PRODUCE UNDESIRABLE FLUTTER AND
                    DYNAMIC INSTABILITY WHICH COULD AFFECT FLIGHT SAFETY.
                    B. Depleted Uranium Balance Weights
                    (1) Some balance weights on outboard elevator and upper rudder are made
                    from depleted uranium, which is a naturally occuring uranium that
                    has been "depleted" of most of the isotope U235. This remaining
                    low-level radioactive uranium, similar to other heavy metals, is
                    toxic if ingested, absorbed, or inhaled into the body. Those
                    weights are identified with legends permanently stamped into the
                    surface of each weight, to assure special handling during
                    maintenance. Protective coatings have been electro-plated on the
                    weights to contain the depleted uranium. If those coatings are
                    penetrated, certain precautionary measures are required to minimize
                    the small health risk.
                    WARNING: REWORK, SUCH AS FILING, SANDING OR MACHINING, THAT WOULD
                    DAMAGE THE PLATING OR REMOVE ANY BASE METAL IS PROHIBITED.
                    INHALATION OR INGESTION OF FILINGS, DUST, ETC., FROM THE
                    WEIGHTS MAY BE HARMFUL.
                    (2) Limited repair of damaged or corroded weights can be accomplished
                    safely if the procedures in subject 51-20-03, hazardous materials,
                    of the Structural Repair manual are used.
                    (3) Replacement of uranium balance weights with tungsten balance weights
                    can be obtained from Structural Repair manual (51-20-03)."
                    #312716
                    Muzzer
                      @muzzer
                      Posted by duncan webster on 18/08/2017 11:50:08:
                      Surely you will get a much more accurate measure of its volume if you simply measure the diameter and length with precision tools, given that it is a length of round bar. I would expect the weight measurement to be the least accurate of the 2 unless you have some snazzy precision scales. The difference you cite between the densities is less than 4%, so your scales would need to be better than +/- 2% or so to be reasonably certain.
                      Murray
                      #312769
                      Cornish Jack
                        @cornishjack
                        Thank you to all for the responses.
                        I'll do the S.G. calcs and see what gives. I'll also see if I can find the Matador 60 series in ME 'cos I think that I was trying to 'build to spec' and it would, presumably, have suggested appropriate material. Not sure if DU was regarded with such horror back then.
                        rgds
                        Bill
                        #312784
                        Mark P.
                          @markp
                          We used to make really good riveting blocks from 707 ballance weights! These were I think DU.
                          Mark P
                          #312791
                          Roderick Jenkins
                            @roderickjenkins93242
                            Bill,
                            The Matador 60 was published in RCM&E. I don't recall any requirement for extra weights for balancing, there's room for an adequately sized crank web.
                            Cheers,
                            Rod
                            #312793
                              Why does this make me think of Repo Man…
                              Advice is to wear gloves to handle and don't try machining it.
                              Personally, I wouldn't walk around with it in my trouser pocket.
                              You can probably sell it for a hefty sum to a company that knows how and is able to use it safely.
                              Ian S C
                                @iansc
                                If it's Uranium there will be little magnetic attraction, probably too small to be noticed. If it's Tungsten Carbide, it will possibly have either Nickle, or Cobalt in it and will be magnetic.
                                Ian S C
                                #313434
                                Hevanscc
                                  @hevanscc
                                  Depleted uranium has the most radioactive U-235 isotope removed, leaving the much less radioactive part behind, so you are more in danger of radiation from bits of Dartmoor granite. Having said that, uranium is a toxic heavy metal like lead so avoid inhaling the dust.
                                  Hywel
                                  Edited By Hevanscc on 22/08/2017 20:25:44
                                  #313444
                                    Except that uranium is radioactive and will be decaying inside you – not like lead which is just a nuisance and can be readily cleared from the system if diagnosed as a problem.
                                    Alpha particles don't travel far, but are very destructive to dna etc due to their mass (compared with, say a beta particle which, while faster, has a mass of only 1/7000th of that of an alpha particle). Cannon ball versus ping pong ball comes to mind.
                                    #313483
                                    Phil Boyland
                                      @philboyland37326
                                      If you can file off a tiny pioece and pop it in the post I can chemically analyse it for you in work. You will knoiw then exactly what it is.
                                      #313602
                                      duncan webster 1
                                        @duncanwebster1
                                        Posted by Hevanscc on 22/08/2017 20:25:12:
                                        Hywel
                                        Natural Uranium is typically 0.7% U235, depleted is typically 0.25% .
                                        Granite can be 20ppm natural U, which is plainly a lot less U235 than DU
                                        This website is very informative. I strongly recommend you don't file a bit off until you know it isn't Uranium.
                                          Ditto.
