Can anyone identify this type of scissor jack
Home › Forums › General Questions › Can anyone identify this type of scissor jack
Viewing 25 posts - 1 through 25 (of 40 total)
  • #267043
    Dan Carter
      @dancarter89683
      Hi,
      Is there a specific name for this type of scissor jack:scissor_lift.jpg
      even better, is anyone aware of how to work out the possible pivot points without me having to dust off my rusty geometry ?
      The appeal is it having no need for a sliding joint as in a normal scissor lift
      Thanks,
      Dan
      #24877
      Dan Carter
        @dancarter89683
        #267046
        Ady1
          @ady1
          On a well known site they are called a lift table
          #267048
          Cyril Bonnett
            @cyrilbonnett24790
            Hi
            A quick search gave the following
            Industrial Scissor Lift Table
            or a home built one.
            http://imgur.com/a/7RW0n
            Cyril
            Edited By Cyril Bonnett on 17/11/2016 21:59:35
            #267049
            Dan Carter
              @dancarter89683
              Cyril – that is where I found the image in the first place unfortunately doesn't help much getting the dimensions worked out.
              Ady – a normal lift table doesn't have the extra/different linkage which gets rid of the need for a sliding joint, that's the bit I'm interested in
              #267051
              Old School
                @oldschool
                Surely you can scale it from the picture and then draw it up to check that you got it right.
                #267054
                Cyril Bonnett
                  @cyrilbonnett24790
                  The second link I posted above has a download for solidwork files
                  #267055
                  Dan Carter
                    @dancarter89683
                    Cyril,
                    Sorry, only read the email update which didn't include the second link – that is extremely helpful (or at least will be once I remember how to use fusion 360 to import the solidworks model)
                    Old School – would have done if necessary, but the picture is of a decorative item, no way of knowing if it even works as shown
                    Thanks,
                    Dan
                    #267057
                    norman valentine
                      @normanvalentine78682
                      Make a quick model out of mecano, if you don't have mecano cut some strips of cardboard.
                      #267060
                      Dan Carter
                        @dancarter89683
                        Norman,
                        Already did (lego, not meccano). The length and position of the short linkage affect whether the top moves vertically only or also horizontally.
                        Am attempting to look at the model linked by Cyril to see whether it is an exact solution or not.
                        #267063
                        JA
                          @ja
                          Except for the screw jack each pivot is the corner of a four sided link system. These are mechanism and are free to move in the vertical plane. The screw jack holds everything together because it is part of two (although only one is actually required) three link systems. A three link system is locked and is not a mechanism. I hope this makes sense.
                          The lift is not far removed, mechanically, for scaffolding. Unless there is a diagonal scaffold pipe in each plane the structure is very likely to collapse.
                          It is quite neat, though. Better than my scissors type bike work bench.
                          JA
                          Edited By JA on 17/11/2016 22:59:22
                          #267065
                            Dan,
                            No promises, but I think you will find this of interest: **LINK**
                            https://archive.org/details/howtodrawastrai01kempgoog
                            duncan webster 1
                              @duncanwebster1
                              The name ought to be 'over complicated'. The sliding joints in my scissor lift are very simple, little wheels running inside folded channel. I have 4 lever bits and a cheap hydraulic jack, the one in photo has 12 and a bespoke leadscrew arrangement. Nuff Sed?
                              #267068
                              Dan Carter
                                @dancarter89683
                                True, but it has more in common with a double scissor lift than a single as regards height vs length (which matters for my purpose), which would double your lever bits. In my case the bespoke leadscrew would be replaced by the guts of an electric scissor jack which I already have, so not quite as pointlessly overcomplicated as it looks
                                #267069
                                  Posted by duncan webster on 17/11/2016 23:31:22:
                                  Sorry, Duncan … I have to disagree
                                  The 'Lab Jacks' that I bought for close-up photography are crude and precarious compared with what Dan shows … [because; as the elevation increases, the support becomes narrower … which is exactly what is not wanted].
                                  https://en.m.wikipedia.org/wiki/Laboratory_scissor_jack
                                  Edited By Michael Gilligan on 18/11/2016 00:18:24
                                  #267071
                                  Paul Lousick
                                    @paullousick59116
                                    Dan,
                                    What is the load capacity of your lift table ?
                                    I can open your Solidworks model but some on this forum may not.
                                    Can you post a drawing with dimensions for them ?
                                    Paul.
                                    Edited By Paul Lousick on 18/11/2016 07:06:31
                                    #267074
                                    Ady1
                                      @ady1
                                      I presume that what makes this do it's job differently is the parallelogram within the structure?
                                      It puts me in mind of that screwcutting attachment which the French chap posted a while back
                                      To my mind it looks like the top left hand side has no real support compared to the right hand side, the cross member goes waaay across to the far right before it has a load bearing point
                                      Edited By Ady1 on 18/11/2016 07:54:34
                                      #267078
                                        Posted by Ady1 on 18/11/2016 07:40:24:
                                        Enlighten me please, Ady
                                        I'm barely awake, but I can't see it as anything other than symmetrical.
                                        MichaelG
                                        'it' being the linkage [excluding the screw].
                                        Edited By Michael Gilligan on 18/11/2016 08:49:04
                                        #267082
                                          I think he means the short arm appears to give support to the RHS. It is perfectly possible to add a similar parallelogram to the LHS.
                                          The question we all want answered is how you decide on the length of the short arm for optimum performance without having to put in any thought effort into 'O-level' geometry.
                                          #267102
                                          Dan Carter
                                            @dancarter89683
                                            Paul, it is not my table, the link was an example found by Cyril.
                                            In the model, the distance between hole centres for the long piece is 20", the short distance between end hole and attachment point of the strut is 7.5" and the distance between hole centres on the strut is 7.492" (??)
                                            However, having tried that ratio in lego, it doesn't work as I expected, the top still moves off to one side as it goes up. Possibly this is inevitable, may have to actually read Michael G's link (thanks for that)
                                            Bazyle – I think a second parallelogram won't work unless the movement is completely vertical, which it doesn't appear to be in the example. Looking like avoiding thought may be impossible (probably would have been quicker in the first place )
                                            #267108
                                            Dan Carter
                                              @dancarter89683
                                              Oops, schoolboy error, used 16 and 6 hole pieced rather than 17 and 7. Works perfectly with ratio as above
                                              #267109
                                                It's congruent triangles (remember those).
                                                As long as top and bottom are identical (but rotated 180 degrees) it should work. Changing lengths will just affect how far it can move.
                                                David Jupp
                                                  @davidjupp51506
                                                  For those wanting to study/measure/play with the SolidWorks model, there is a free viewer program available. Handy if you don't have a CAD system that can import the files.
                                                  #267112
                                                    Posted by Neil Wyatt on 18/11/2016 10:37:38:
                                                    Do I remember congruent triangles? No.
                                                    I've always been obtuse.
                                                    MW
                                                      @mw27036
                                                      I'm astounded by how much discussion this has caused beyond discovering it's namesake, size and tolerable load.
                                                      Michael W
